Old 11-26-2003, 09:10 AM
chezicrator chezicrator is offline
Does this car have crank walk?
Hello, I went to check out a 95 GSX yesterday. The car is in great condition interior/exterior wise. Great custom interior, but the problem is that I heard a ticking/clicking noise coming from the engine when it was running. I recognize the noise from my friend's GST who's car is no longer running (He claims it's the motor mounts). Is this that dreaded crank walk I've been hearing about? I've read and it's characterized as the ticking noise with a faulty shift. If you hear the noise but experience no problem with the shifter, is it still the same problem? I was under the impression that if u didn't get it by like 50-60k miles it wouldn't happen. This car has 92k.
Also one more thing.. one of the cv joints on the car is busted. Is it safe to assume that the rest could be shortly behind (the car has like 7 or 8 right?). Because that would be one hell of a dagger to my wallet.
I was planning on taking my mechanic with me today, but for some reason I doubt he knows about crank walk or how to detect it. This guy had looked at my friend's GST before and told him his motor mount was busted.
Old 11-26-2003, 09:26 AM
one more question..
How much would I be looking at to have the crank shaft replaced as well as all the bearings... Over 2k?
Old 11-26-2003, 05:11 PM
FourG63 97GST FourG63 97GST is offline
Send a message via AIM to FourG63 97GST
Did you drive the car? how does it drive and shift?
it just be just lifter tick
-Agim
Old 11-27-2003, 11:08 PM
kjewer1 kjewer1 is offline
AF - Advisor
On a 2g, the motor will stop running before you hear any audible signs of CW in most cases. The ticking is the crank trigger plate hitting the sensor. Once that destroys itself the motor wont run. This is only true for 2g, 1g does not have a seperate crank angle sensor, its incorporated into the cam angle sensor on thehead.
Replacing the crank and bearings is cheap, usually less than 400 in parts. Labor can get up there, but I can do it in a couple hours. Who knows what a shop will charge. The real kicker is most of the time its unsuccessful anyway...
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Does this car have electronic throttle ? jrecken LaCrosse/Allure 2 11-23-2008 12:06 AM
Why does this car have a light and plug but no harness? Musashi3000GT Altima 2 01-05-2005 06:35 PM
Does this kit have an engine?? lotusmark2 Car Modeling 10 06-24-2004 04:32 PM
Does this woman have the nicest ass you've ever seen? Sham365 COMPLETELY off-topic 20 02-07-2002 09:12 PM
