Old 11-25-2003, 08:31 PM
mhuntca mhuntca is offline
Cold Air In Passenger Compartment
Has anyone else out there had a problem with outside air entering into the vehicle on the passenger side under the dash? It's fairly close to where the in cabin air filters go.
I have a 2001 Suburban with this problem and have had it into the dealer a couple of times because in the winter it's very cold on the passenger side!
The dealer always says they've fixed the problem ... but they haven't.
Any suggestions on a fix?
Thanks
Old 12-12-2003, 03:08 PM
terryinatlanta terryinatlanta is offline
Re: Cold Air In Passenger Compartment
Thanks
Your dealer should know that Chevy issued a TSB ( technical service bulletin ) about this problem. Ask them about it. Maybe they know and just didn't do a good job. If they are not aware of the fix, I can probably find the TSB if you email me.
Old 12-13-2003, 07:26 AM
99ssconv 99ssconv is offline
Passenger Side of Vehicle Colder/Warmer Than Driver's Side (Repair HVAC Case to Cowl Seal)
1999-2001 Chevrolet and GMC C/K Pickup (Silverado, Sierra) and Utility (Suburban, Tahoe, Yukon, Yukon XL) Models
2002 Cadillac Escalade
Condition
Some customers may comment that the passenger side of the vehicle may be:
Colder than the driver's side when the heat mode is on.
Warmer than the driver's side when the air conditioning (A/C) mode is on.
There may be dampness on the vehicle dash assembly when the A/C mode is on.
Cause
Condition may be due to poor sealing of the HVAC air inlet case to the front of dash or the recirculation mode door actuator may not hold the recirculation door closed while driving.
Correction
Replace the recirculation door actuator (if necessary) and repair the HVAC case to cowl seal using the following procedures:
Place the A/C control in the manual heat mode.
Remove the fixed mast radio antenna.
Open the hood and install fender covers.
Remove both wiper arm assemblies using the following procedure:
Disconnect the washer solvent hose from the air inlet grille panel nozzle.
Remove the cover from the wiper arm retainer. Remove the retainer.
Important
Use a battery terminal puller in order to remove the wiper arm.
Rock the wiper arm back and forth in order to loosen the arm from the drive shaft. Remove the wiper arm.
Lower the hood.
Remove the air inlet grille panel using the following procedure:
On each end of the air inlet grille panel is a rubber flap for the hood hinge cutout. Lift this flap and remove the air inlet grille panel attaching screw.
Remove the air inlet grille panel center top push pin.
Remove the clips that position the forward edge of the grille panel to the top of the cowl.
Disconnect the windshield washer supply hose from the bottom of the grille panel.
Remove the air inlet grille panel by sliding the panel rearward up the windshield and out.
Just to the left of the right hood hinge, on the horizontal surface of the cowl, locate a cover that is sealed in place. The cover has TRW stamped into it.
With a sharp knife, cut out the panel following the panel impression in the sealer tape.
Place a lifting device between the cover and the dash. Lift the cover enough to allow another tool to depress and release the front retaining tabs by pushing rearward on them. Remove the cover.
Look through the opening where you just removed the cover. You will see what looks like a piece of foam about 76 x 127 mm (3 x 5 in). This is the A/C recirculation door that is within the HVAC module.
Reach into the opening and carefully pull on the air inlet recirculation door. If the recirculation door moves with very little effort, replace the air inlet (recirculation) door actuator (Manual systems only). For systems with the Automatic Temperature control, initialize the system using published Service procedures.
Between the top of the HVAC air inlet module (appears as a 6 mm (1/4 inch) black strip) and the cowl sheet metal is a foam seal. This foam seal may be improperly positioned or damaged in some way (insufficient crush/sealing). This may allow outside ambient air to enter the passenger compartment incorrectly (under driving conditions). This can be corrected using the following procedure:
Important
It is imperative that a good seal be achieved over the entire surface areas (no voids or skips), especially around the rear and sides of the HVAC case to cowl areas.
Seal the area between the cowl and HVAC case with RTV Silicone Rubber Sealant, P/N 12345739 (in Canada, use P/N 10953541).
Using your finger, from the engine side of the cowl, ensure that the foam is stuck nicely to the HVAC module and does not have any distortions.
From the engine side of the cowl, working through the opening in the horizontal surface of the cowl, place a shop cloth into the opening and cover the blower fan. This keeps silicone from dripping onto the motor and causing an imbalance condition.
From the engine side of the cowl, working through the opening in the horizontal surface of the cowl, apply the RTV silicone to bridge the gap and cover the foam between the cowl sheet metal and the HVAC module case. Inspect your work with a light and a mirror. Ensure that no gaps or skips are present in the RTV seal.
Inspect your work for potential drips, runs, etc. If no problem is seen, remove the shop cloth covering the blower motor.
Apply a 3 mm (1/8 in) bead of weatherstrip adhesive, P/N 12345097 (in Canada, use P/N 10953479) around the opening in the horizontal surface of the cowl, where the cover fits into the cowl.
Place the cover on the workbench, top on the surface, and apply a 3 mm (1/8 in) bead of weatherstrip adhesive on the edge of the cover.
Place the cover into the cowl opening and snap into place.
Apply another bead of weatherstrip adhesive around the joint between the cover and the top of the cowl. Smooth this bead into a smooth surface with a finger or tool of some kind.
Place the leaf screen to the cowl. Attach the washer supply hose to the bottom of the air inlet grille panel. Do not place the fasteners in at this time.
Install the radio fixed mast antenna. Tighten 1/4 turn after contact is made with the base.
Lower but do not close the hood.
Center the opening in the air inlet grille panel around the antenna mast and then install the air inlet grille panel retaining screws. Tighten
Tighten the screws to 2 N·m (18 lb in).
Raise the hood.
Reinstall the air inlet grille panel center retainer and front edge retaining clips.
Cycle the wipers to ensure the wiper system is in the parked position.
Important
Inspect the windshield lower edge on each side. About 51-76 mm (2-3 in) from the bottom, you will find a 13 mm (1/2 in) long black mark embedded in the glass. The black line is the position for the wiper blade to be in when the wiper system is in the parked position.
Install the wiper arm assemblies. Position the wiper blades just below the black marks in the windshield.
Install the retaining nuts. Tighten
Tighten the retainers to 25 N·m (18 lb ft).
Reconnect the washer hoses.
Remove the fender covers.
Close the hood.
Parts Information
Part Number
Description
12345097
(In Canada use P/N 10953479)
Adhesive, Weatherstrip
12345739
(In Canada use P/N 10953541)
Sealant, RTV Silicone
Old 12-14-2003, 07:52 PM
Smile Thanks 99ssconv!
Thanks for the information ... it's much appreciated.
Where I live it we can get winter cold spells of -20 to -30 degrees and that cold air coming into the passenger side is brutal.
240sx s14 CARB Legal Cold Air Intake? Dope Minded Technical 3 01-26-2011 03:48 PM
Heater starts blowing cold air on passenger side? BDeHaven13 TrailBlazer | Trailblazer EXT 3 03-10-2010 10:14 PM
Replacement Passenger Compartment Air Filter gyee Camry/Camry Hybrid/Vista 2 04-19-2007 11:34 AM
passenger compartment air filter / mpg max3456 TrailBlazer | Trailblazer EXT 8 03-30-2006 07:29 PM
Passenger Compartment Air Filter paxton66 C/K 4 09-30-2003 08:52 PM
