Old 11-25-2003, 05:40 PM
duckydsp's Avatar
duckydsp duckydsp is offline
Want 2 turbo
I am going to turbo my 98 gs. I am making this list to I know what exactly to have. Please let me know if I missed anything or other suggestions.
-New pistons and piston rings
-New camshaft and new rods, valves, and springs
-Have the block bored and head redone
-New fuel pump, regulator, hoses, fittings, and lines
-New ECU
-Boost gauge
-The stage 2 Hahn Racecraft kit
-super 16g or t25?
-BOV
-Boost control
-BOV return
-Exhaust manifold
-Downpipe
-Intercooler-2" Compressor outlet, 2 1/4" intercooler outlet
DSF
1998 Green Mitsubishi Eclipse GS- Vibrant Ram Intake, Greddy Evo2 cat-back, front and rear strut bars.
2 Kicker L7s, amp coming soon
17" white Motegi RT5 rims, Quwhees 12-piece wide-body kit will be put on....... someday
Old 11-25-2003, 06:00 PM
FourG63 97GST FourG63 97GST is offline
Send a message via AIM to FourG63 97GST
injectors
fuel control
how much boost/power are you trying to make?
-Agim
Old 11-25-2003, 07:18 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
Re: Want 2 turbo
not all of that is needed, and a lot of little things are. tons of little things
Old 11-26-2003, 12:16 AM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
Re: Re: Want 2 turbo
yes all of that is needed if he plans on running more that about 12-14 psi, and usually someone wouldnt pay all that money and put a turbo on there car to run 7 psi... hes got it right, and yes there are little stuff like oil lines, plugs, gaskets, and longer headbolts (i underlined that one cause it is a must, otherwise your head will start to lift off the block) and like talon said how much psi are you planning to run...for a starter turbo i would suggest the 14b, so you can get the hang of it and tune it right and then upgrade later down the line, cause that turbo spools quick and can produce a pretty good amount of boost. you will get sick of the t25 after a while and you will want more boost, a t25 would be perfect if you werent doin the internals. good luck... let me know if you need anymore help!
Old 11-27-2003, 03:40 PM
duckydsp's Avatar
I am planning to run over 12 psi but under 15 psi. I don't want to strees my engine too much and mess it up unless I have something to back it up. I also hope that this is going to push me over 300 hp. Would I be able to get a 14b from Hahn Racecraft?
DSF
Want to turbo a 96 Eclipse 2.0 non turbo donidavis Engine, Transmission and Drivetrain 7 12-02-2010 08:23 AM
I want turbo parts. 99IntegraGSR Forced Induction 0 03-07-2004 09:28 PM
want turbo! P|aYaZ Forced Induction 2 01-06-2004 09:31 PM
want turbo need4bst Celica 3 09-19-2003 03:40 PM
Who wants turbo? 90civichatch '88 - '91 Civic | CRX | Wagon | Shuttlee 4 05-13-2003 05:53 AM
