Old 11-25-2003, 09:07 AM
Fasteddie1 Fasteddie1 is offline
Question 98 GP GT Auto headlights intermittent off and blower problem
Strange problem that I thought you guys may be able to help me with....My automatic headlights shut off by themself and at the same time the blower quit working on settings 1-4. I had to turn on the headlights switch for headlights. This has happened twice so far in the past couple of days. This morning everything worked fine. Any Ideas?
Thanks.
Old 11-27-2003, 03:10 PM
kilroypr's Avatar
kilroypr kilroypr is offline
Send a message via MSN to kilroypr Send a message via Yahoo to kilroypr
Re: 98 GP GT Auto headlights intermittent off and blower problem
Thanks.
The only thing I might think of is the DRL circuit. I disabled it because I want to turn mi lights on manually and the autolight on feature stopped working(that is what I wanted).
There is a 10amp fuse on the glove compartment fuse box that is for DRL and the auto light on feature. Checked if is broken or loose.
IF not then the DRL circuit could be the issue.
All this is guess work based on my DRL/Auto light on feature.
Do not quote me on that.
Old 12-06-2003, 09:56 PM
GTPCatz GTPCatz is offline
Banned
Check this out....your ignition switch is dead
http://www.clubgp.com/newforum/tm.asp?m=553522
Old 03-29-2004, 12:07 PM
Changing the ignition switch fixed the problem!! Thanks!
Old 03-29-2004, 06:57 PM
kilroypr's Avatar
Interesting, in my case if I leave the hi beam for a long time all the dash will go dark and the lights will go out too. I replaced the ignition switch under the steering column because the DIC will go out from time to time. The DIC got fixed but the hi beam issue is still at large. I would think that the light switch could be the issue. What you think?
intermittent ac/heat blower '00 e320 tpking E-Class 1 07-12-2009 10:51 PM
Auto lights turn off when blower motor turned on Pontisteve Regal 6 05-31-2008 07:01 PM
auto headlight shut off Ricker500 Grand AM 2 06-22-2007 11:29 PM
need auto headlight on/off product A Traveler What do you want to know? 0 03-10-2005 08:58 AM
Auto Headlight on/off control 98 Aurora a_batchelor Aurora 5 07-24-2003 03:27 PM
