Auto lights turn off when blower motor turned on
My 98 Regal has weird electrical issues.
#1 The auto headlights shut off when the blower motor turns on, in the 1 - 4 position only usually. Sometimes position 5 too. Turn the fan off, and the lights come back on. Also sometimes turning on the Rear Defrost turns the lights back on. I'm thinking a body control module, or possibly a cicruit breaker? #2 Can't seem to get the right rear brake light to work no matter what. The turn signal lights work, and the bulb is definitely good. Tried several. No corrosion. #3 Keep burning up the 194 bulb in the front orange Daytime Running Light, one side only. Only lasts a few days at best. |
Re: Auto lights turn off when blower motor turned on
BTDT. ![]()
Where exactly is the switch located? And do you feel 100% that's what the problem is? What's basically involved in replacing it? Is this one of those cars that's hard to swap it because you have to impossibly snake the harness down thru the column? Thanks so much! |
turn signal switch too.
also there is a connector in front signal that can go.(58$ ripoff) Cheers Stripe |
And tell me more about the connector in front signal!! This car has always had a problem burning up the bulb in one of the Daytime Running Lights! The one side only lasts a couple days. I want to say I already replaced a bulb harness connector on that thing. As I recall, it's made to be replaced independent of the whole wiring harness. At least GM got that part right, but something causes that DRL to get very hot and burn up the connector. It was somewhat melted looking when I pulled it. What causes all that?? The bulb does not appear to be staying on when the car is off. |
Switch is not that difficult to replace but still a tedious job. Steering wheel does not need removal. For safety disable driver's airbag by removing the fuse. About a 1 hour job. See procedure below. ![]() Quote:
Thanks to this forum, and other threads about the same topic, I was able to find out (before ever touching the car) that the Ignition switch was the problem. And that the contacts inside that switch are actually hi quality (silver?) contacts, which don't really go bad. They just get carboned up and block conductivity. I also found out exact which tools were needed, and ordered them (the precision nutdrivers that worked to remove the torx screws) before I ever did the job.
Then, another user informed me that I could clean the switch and not replace it. He even outlined how to reassemble the switch (a 2 man job), and realign the clock spring correctly. I also found that using a pencil eraser works wonders for cleaning contacts. Don't scrape the coating off the contacts with a wire brush! All said and done, I fixed it in about an hour, and didn't even have to buy the switch! The cleaned switch works like new, and saved me about $75 on that, plus any labor of doing the job. Thank you all! |
