Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 11-25-2003, 08:33 AM
xsimpleaznx's Avatar
xsimpleaznx xsimpleaznx is offline
wheel making noise, bearing?
wondering if anybody can help me out. when i drive i sometimes hear a squeeling noise coming from my front right wheel i think. my friend said that its the wheel bearing because it makes the noise without me using the brakes, and that it cost about $300 to fix, is he right? another thing is he said my brake booster is messed up because when im at a stop and if i apply hard pressure to the brake my rpm goes up to about 2k rpm and goes back down, is that normal for a car to do?
Old 11-25-2003, 07:36 PM
BullShifter's Avatar
Re: wheel making noise, bearing?
you don't have to be braking in order to hear a brake noise - the wear indicator can rub any time! Its hard to fix a noise without hearing it in person.
Why are you pressing the brakes hard when your stopped??? Thats a good way to blow-out seals, seems as though you've already done that to the booster.
Old 11-25-2003, 08:12 PM
i dont press the brake hard when im stopped, i always drive with regular mild braking. its just that when my friend changed my front brake pads, he stepped on the brake to test it i guess and he said that my brake booster was messed up. i never noticed before that my rpm jumped when i put my foot on the gas because i never step on it that hard, so maybe he messed it up? but i doubt it could have happened with him doing it just that one time. i didnt get my rotors resurfaced because he said that it was still ok, i was considering getting cross drilled and slotted but i read that the reduced surface area kinda equals out to blanks so i decided to save the money, would changing the rotors stop the squeel?
Old 11-25-2003, 08:17 PM
SiGNAL748's Avatar
SiGNAL748 SiGNAL748 is offline
Send a message via AIM to SiGNAL748 Send a message via MSN to SiGNAL748
i'm almost positive its not your wheel bearing, when wheel bearings go bad, they don't squeek. Instead they make like a "hollow-hum" (sorry i can't explain it any better)
how do i know this? i have a bad wheel bearing myself.
but i could be wrong..
Old 11-25-2003, 11:11 PM
Possibly low quality pads?
Pads/retainers/shims not lubed or used?
2000 Venture "buzzing" wheel bearing ? pjw73nh Venture 9 02-29-2012 07:23 PM
Front wheel make noise maxl1961 Rodeo | Passport | MU 13 06-03-2011 05:06 PM
96 dodge ram making noise from front of tranmission , maybe wheel bearings bratt Ram Pickup | Ram SRT10 5 05-21-2009 09:19 PM
Grinding Wheel, Not the bearings. Kbrickman Cavalier Problem Diagnosis 5 04-18-2009 10:22 PM
Left back wheel making noises when accelerating Jessica38 Cabrio 0 08-27-2007 12:54 PM
