Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora
Old 11-24-2003, 06:30 PM
dakine_stuff dakine_stuff is offline
Question A/C not working all the time
I have a 97 jetta GLX VR6, and the A/C usually works after the car has been running awhile. But if you down shift or decrease speed it will stop blowing cold. When it does work it's super cold. This problem is driving me crazy! Has anyone had this problem?
Old 11-24-2003, 11:58 PM
IcemanE30 IcemanE30 is offline
It could be the condenser fan. If the fan is not working it is raising the system pressure causing the temp to rise. When you drive especially continuesly the air blowing through the grill cools the condenser. This may be it, just a guess though. Good luck.
Old 11-25-2003, 09:43 PM
OBATDDSD OBATDDSD is offline
Re: A/C not working all the time
when you first start your car, turn the a/c, pop the hood and check the your a/c compressor and see if the clutch is engaged.( the center hub will be spining. ) It sounds like your low on charge. trace your a/c lines from the compressor to the fire wall and to the condenser.. I justed fixed my wife's jetta. it had a leaking fitting at the firewall where that plastic covers both lines. look for oily dirty spots. thats the sign of a leak. You won't really know until you hook some gauges and see what the pressure readings are. It will give you an idea where to look.
keyless entry not working all the time in 2000 HT mabyrd C70 0 10-18-2005 10:41 PM
93 Camry Speedometer not working all the time goodolecamry Camry/Camry Hybrid/Vista 0 11-27-2004 02:42 PM
Brake lights not working all the time ZR800 C/K 3 08-17-2004 07:17 PM
Back speakers don't work all the time White GPGT Grand Prix 1 10-27-2003 07:51 PM
2000 Z3 door handle doesnt work all the time fusionpunch Z3 3 03-28-2003 06:51 AM
