Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 11-24-2003, 05:50 PM
krt krt is offline
96 Dodge 3500 not charging no tack no check engine light
96 dodge alt not charging no tack no speedometer no check engine light no wait to start light (diesel) traced the wiring checked the PCM is ok ingition switch is OK back of the instrument cluster is ok power and ground to the PCM is ok all fuses are good if anyone has had a similar problem please!! let me know what to look for next I'm LOST
Old 12-04-2003, 01:15 PM
challenger1 challenger1 is offline
I have the same problem. Wondering if you figured it out?
Old 12-20-2003, 09:00 PM
krt krt is offline
Re: 96 Dodge 3500 not charging no tack no check engine light
i'm still having the same problem i tested the pcm, the ground system the ingition switch the asd relay and both of the fuel relays and tested the power and the ground at the pcm and i still can not locate the problem have you had any luck??
Old 01-06-2004, 09:44 AM
Re: Re: 96 Dodge 3500 not charging no tack no check engine light
took mine to the dealer they told me there are 12 different grounds on the truck, one of them had shorted. Mine was on the front of the engine driver side near the valve cover. They just cleaned the contact area and replaced the bolt. when one of the grounds short out it shuts down the whole pcm system. good luck!
Old 07-23-2004, 03:23 PM
Ken Lott Ken Lott is offline
Re: Re: Re: 96 Dodge 3500 not charging no tack no check engine light
[quote=challenger1]took mine to the dealer they told me there are 12 different grounds on the truck, one of them had shorted. Mine was on the front of the engine driver side near the valve cover. They just cleaned the contact area and replaced the bolt. when one of the grounds short out it shuts down the whole pcm system. good luck![/QUOTE Okay Guys take a look at the speed sensor located on a mounting bracket over the harmonic balancer. I had the same problem with my 97 ram diesel.
Check Engine Light..... Stinff Equinox 2 11-01-2010 11:15 AM
Radio**check engine light controls Impala____Chevy Impala | Impala SS 1 02-20-2010 11:44 AM
97 ram 4x4 shaking, check engine light on, one tire is wrong size cscafe Ram Pickup | Ram SRT10 2 11-18-2009 03:53 PM
Check engine light on 89 cherokee hoopdaddy6 Cherokee 3 04-09-2009 06:16 PM
1994 Ranger 4cyl check engine light/ABS light wont start on cold mornings 94rangerproblems Ranger | Courier 1 03-21-2009 07:40 AM
