Old 11-24-2003, 04:11 PM
97copcar 97copcar is offline
o2 sensor
Does anyone know how many o2 sensors there are on a 97 b4c? I do not have the ability to get under the car right now to look. Thanks.
Old 11-24-2003, 05:30 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
Re: o2 sensor
dont konw off the top of my head, but ill check at work tomorrow. ill post when i get home. i think its two. one after each of the cats before the Y-pipe, but ill doubble check and get back to ya.
Old 11-24-2003, 08:59 PM
Re: o2 sensor
89IROC&RS,
Thanks. That was what I was thinking also, but I won't have the tools to under the car until this weekend.
Old 11-25-2003, 09:27 AM
RABarrett RABarrett is offline
Re: o2 sensor
TRhe easiest way to determine that is to remember that OBDII checks any and all convertors in the exhaust. That requires two O2 sensors for each cat, one before and one after. A two cat system will therefore require four O2 sensors. There is no hard and fast rule since there are so many exhaust packages for each engine package. Ray
Old 11-25-2003, 05:50 PM
89IROC&RS's Avatar
Re: o2 sensor
hey 97copcar, checked the shop manual, from what i can tell, the six cylenders get a three way cat, which has a O2 sensor before and after the cat, while the VIN P motor, the 8 cylender, which i assume you have, is an oxidizing cat, and has a single O2 sensor down stream of the cat. so you should only have one to worry about. but best way to find out, get under it and look around. good luck.
Old 11-25-2003, 06:08 PM
Re: o2 sensor
89IROC&RS,
I am going to repo my jack stands on Saturday. I'll crawl under and look. Thanks for your help.
Old 11-25-2003, 06:24 PM
89IROC&RS's Avatar
Re: o2 sensor
no prob, good luck.
o2 sensor danielgast46 F Series 0 03-15-2009 09:39 PM
Replacing Evap. canister Control Valve, Boost Sensor, and Knock Sensor? raja Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 16 06-04-2007 03:25 AM
Knock sensor and O2 sensor jmmax Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 4 02-24-2004 11:51 AM
