Go Back   Automotive Forums Car Chat > Racing > Rally
Old 11-23-2003, 08:05 AM
UKSupraboy's Avatar
UKSupraboy UKSupraboy is offline
Thumbs up 2004 Evo WRC pics.
Hi folks, most of you have probably seen these pics before and I don't know if they are official or not, but I thought they may interest some people on here, maybe some 'sucker for punishment' will build one?
Technical Specification:
OVERALL LENGTH 4360 mm
OVERALL WIDTH 1770 mm
WHEEL BASE 2600 mm
TRACK FRONT AND REAR 1550 mm
WEIGHT 1230 kg
ENGINE MODEL 4G63, 4 cylinder, 16 valves DOHC turbo charged
BORE-STROK 85,5 x 86,9 mm
DISPLACEMENT 1996 cc
ENGINE MANAGEMENT SYSTEM Magneti Marelli, multi injection
MAXIMUM OUTPUT 300 PS / 5500 apm
MAXIMUM TORQUE 55 kg-m / 3500 rpm
CLUTCH Carbon triple plate
TRANSMISSION Ricardo/MMSP 4 wheel drive, 5 speed, limited slip differentials front centre and rear
MAX. SPEED 220km/h
SUSPENSION Front and Rear McPherson strut, coil springs, anti roll bar
STEERING Power assisted rack and pinion
BRAKES Brembo, ventilated disks 370 mm diameter tarmac, 300 mm gravel, 328 mm snow, 8 pot calliper tarmac, 4 pot gravel and snow
WHEELS ENKEI magnesium cast 8x18 tarmac, 7x15 gravel 5,5x16 snow
TYRES Michelin
FUEL TANK CAPACITY 90 litres
SEATS Recaro composit
COCKPIT Components Sabelt
INTERCOM SYSTEM & HELMETS Stilo
CAR DESIGN Using PTC Pro Engineer
* Submitted to FIA homologation
BSR (Sweden) A4 1.8T 225+hp 330Nm
Old 11-23-2003, 08:56 AM
Vric's Avatar
Vric Vric is offline
Re: 2004 Evo WRC pics.
Overal look is great, but the Wing (look a lot like the 206 one) don't fit this car at all
Old 11-23-2003, 09:04 AM
joecwlaw's Avatar
joecwlaw joecwlaw is offline
Re: Re: 2004 Evo WRC pics.
yes, agree. What is the problem with the wing??? can it really make any downforce?
Old 11-23-2003, 09:07 AM
EMAXX's Avatar
EMAXX EMAXX is offline
Send a message via AIM to EMAXX Send a message via MSN to EMAXX
That wing is a little bit weird, but everything else, I think looks pretty good. I like most of it.
Old 11-23-2003, 10:23 AM
freakray freakray is offline
AF Modelrater
Why exactly IS there a rally forum on AF?
AF User Guidelines
Old 11-23-2003, 04:47 PM
OPM's Avatar
OPM OPM is offline
Send a message via ICQ to OPM
Re: Re: Re: 2004 Evo WRC pics.
you can be sure they tested it a lot
Old 11-23-2003, 04:54 PM
AF Modelrater
Honestly, the new Mitsu WRC is already being discussed in the rally section of AF, you are all welcome to join the discussion there:
http://www.automotiveforums.com/vbul...71#post1339471
AF User Guidelines
Old 11-23-2003, 11:04 PM
SuBaRuRuLeS's Avatar
SuBaRuRuLeS SuBaRuRuLeS is offline
The wing is out of place
UU-UR-EX
Old 11-24-2003, 05:02 AM
RallyRaider's Avatar
Zomby Woof
Looks great except for the rear wing as everybody has already mentioned. Very strange since you'd think the further back the more downforce it would generate. Only thing I can think of is that the lower element of the Peugeot style double wing needs to be in close proximity to the windscreen to operate. Either that or they don't want too much downforce at the rear in order to keep the car balanced.
Must be set up to allow for heaps of front wheel travel with those massive wheel arches and clearance.
WRC cars certainly seem to be getting more radical. First the new Focus and now this!
Old 11-25-2003, 07:52 AM
exhaust smoke's Avatar
exhaust smoke exhaust smoke is offline
Love it!! but once more...get rid of that wing!! A nice GT Scooby style wing will go down a treat on that.
The real question is...will Tamiya/Fujimi/Hasegawa make a kit of it??
Old 11-25-2003, 09:36 AM
UKSupraboy's Avatar
Thought that I would let you guys know that I started building it over the weekend from the VII kit I had laying around. Will post pics when the front end is done.
As for the spoiler, the shape is to give some lateral force, if thats the right word. The force produced by a surface goes at 90degrees to that surface. This means that as the wing curves the force is pushing towards the centre of the car, increasing high speed straight line stability. Subaru achieved this with multiple vertical elements on their car.
As for the position, this is due to the lever effect, force x distance etc. The further away from the pivot (rear axle) the downforce is applied, the more weight or force is required at the front. This means that by moving the spoiler forward, they can massively increase downforce without requiring more weight at the front to prevent the steering lightening at high speed.
Maybe all my hours studying aeronautics in the airforce weren't wasted after all.
Richie
Old 11-26-2003, 08:50 AM
skowa skowa is offline
for me for the first look the wing looks preaty smart, I think it grabs "clean" and "fast" flowpath going from the roof of the car. another reason to move it forward is, maybe, to move point of applying aerodynamical force generated by the wing closer to the centre of gravity of the vehicle.
I agree it looks quite strange but I am sure they had good reason to do it this way
Old 11-29-2003, 03:27 AM
Zomby Woof
Awesome, maybe now we can get this thread moved back to the modelling forum!
Old 11-30-2003, 01:08 PM
Guido Guido is offline
although not a specialist in the aero-field, I also thought that it had to do with the proximity to the windscreen. Seems logical because otherwise the wind would probably drop too much if the wing is too far in the back.
Mitsubishi Evo WRC Rally Driver vs Road Race Driver trev0006 Car Videos 0 01-07-2010 10:10 PM
Mitsubishi Lancer EVO WRC - something different mikkod WIP - Motorsports 10 11-03-2005 08:08 AM
2004 Evo vs. 2004 S2000 JohnC24 Lancer 27 01-09-2005 02:06 PM
wrc evo 7 pics 91p10nizmo Car Modeling 2 02-05-2004 02:49 PM
Mitsubishi Evo 7 WRC **PIC** Vric Car Modeling 30 02-12-2003 11:28 AM
