Go Back   Automotive Forums Car Chat > Games > Gran Turismo Series
Old 11-22-2003, 05:09 PM
driftu's Avatar
driftu driftu is offline
Send a message via MSN to driftu
Unhappy help
what would you do to the WRX to fix under steer
i am fresh out of ideas
Old 11-22-2003, 08:37 PM
SchuberT's Avatar
SchuberT SchuberT is offline
Re: help
you could put harder tires in the back, or increase the spring rate in the back... basically anything that could produce a little slippage in the rear...
Read the FAQ please.
https://www.facebook.com/KBModelwerks/
Call me Matthew.
Old 11-30-2003, 03:54 AM
simdel1's Avatar
simdel1 simdel1 is offline
yep, or you could also try softer front tires, and lower front spring rates.
you could also stiffen up the rear stabiliser bar, or soften the front...or both.
Simon
Old 12-10-2003, 10:52 AM
Ruperto Ruperto is offline
put some positive camber on the front wheels, use hard rear tyres, put as much power as you can to the back....
-you must always push the limits because if you never fail, you will never succeed-
