Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 11-22-2003, 01:57 PM
Scott78 Scott78 is offline
Question 1996 SL Idle Question
I have a 1996 Saturn that I basically only use for work. The car only has 22,000 miles on it.
The problem I am having does not seem major. But I would like to get to the bottom of it before it gets any worse...
When the car eventually gets hot and I come to a complete stop the idle will drop to 550-600rpms almost as if it were going to stall and then jump back up to its normal 700+ rpms.
It did not d0 this or I did not notice this before I had gotten the valve cover gasket changed.
I also changed the Air Filter and the PCV valve today to see if it would help any. At first it seemed like the PCV valve was helping out a little bit. But then it started doing the same thing.
Does anyone know what else could be causing the idle to drop below its normal idle of 700+rpms to 550-600rpms for a second or so. And then come back up. Like I said. It studders a very little bit and then come right back up to normal. Again this only happens when the car is running hotter ( Stop and go traffic ) probably when the fan is kicking on and off. Please let me know what else I should be looking into.
Thanks
Old 04-30-2004, 02:12 PM
saturngrrl saturngrrl is offline
Re: 1996 SL Idle Question
I have a '96 SL1 and I had a similar problem (now I have the opposite!). I had my spark plug wires changed and a fuel injector flush and it stopped doing that. My engine also runs a little hot sometimes, mostly in traffic as you said. Don't know if the two are correlated, but its definitely annoying!
1996 Monte Carlo Z34/ Cutlass Supreme 3.4L Idle Learn Procedure 96cutlass3.4 Monte Carlo 0 06-17-2010 10:43 PM
96 xj6 rough idle redkitty XJ6| XJ8| XJ12 | XJR 1 05-16-2010 09:13 PM
96 Cutlass Supreme w/ Rough Idle, but drives good chrisluna Cutlass Series 1 09-17-2009 07:29 AM
1996 idling issues tim christopher Rodeo | Passport | MU 5 10-04-2005 09:06 AM
1996 Idle increase/decrease with possible hissing noise! ortred Explorer | Explorer Sport Trac 2 01-24-2004 04:13 PM
