Old 11-22-2003, 01:44 PM
rx7king's Avatar
rx7king rx7king is offline
Question polycaps???
this may be a stupid question, but what are polycaps used for, and why is it necessary to have them
Old 11-22-2003, 02:18 PM
Ferrari TR's Avatar
Ferrari TR Ferrari TR is offline
Not A Hoarder!
Tamiya uses them to mount wheels.
You can use small RC fuel tubing to replace them...
SCCA 7, The lost Z
Old 11-22-2003, 02:20 PM
Lambo003's Avatar
Lambo003 Lambo003 is offline
Polycaps are usually enclosed in the brake housing and are what your wheel shafts slide into to hold your wheels on. . .
Chuck
Old 11-22-2003, 02:26 PM
SchuberT's Avatar
SchuberT SchuberT is offline
Re: polycaps???
a lot of times they're used to keep the spacing between the chassis and wheels right... the build instructions show you where to put them
Read the FAQ please.
https://www.facebook.com/KBModelwerks/
Call me Matthew.
Old 11-22-2003, 09:33 PM
rx7king's Avatar
Re: polycaps???
i know how to use them, but i dont see how they are helpfull
Old 11-22-2003, 10:07 PM
freakray freakray is offline
AF Modelrater
Re: Re: polycaps???
Ummm....they hold the wheels in place so they don't fall off the model. You don't think that is helpful?
AF User Guidelines
Old 11-22-2003, 10:10 PM
rx7king's Avatar
Re: polycaps???
but you dont glue the polycaps, you place them inside, and glue the thing around them
...so as far as i can tell, its not them thats holding the wheels on
Old 11-22-2003, 10:14 PM
AF Modelrater
Re: Re: polycaps???
You press the wheel into the polycap, the polycap is held in place by the retainer. The retainer holds the polycap, the polycap holds the wheel.
Try leaving the polycap out and see how well the wheel stays in place.
Is it that difficult to understand?
AF User Guidelines
Old 11-22-2003, 10:17 PM
cyclone1410's Avatar
cyclone1410 cyclone1410 is offline
Honda Convert
Re: Re: polycaps???
I can only assume that you are talking about a Tamiya kit. If this is the case then the male pin that is part of the wheel pushes through the plastic "thing" that is glued around the polycap and pushes into the polycap. The poly cap is a firm fit onto the wheel pin and holds it in place so that the wheel doesn't just fall off.
The same applies in reverse for Fujimi and Aoshima kits - the polycap is in the wheel itself.
If you are still not convinced, try fitting the wheels without polycaps and see how you go then.
Good Grammar is Not a Time of Waste.
Old 11-23-2003, 02:07 AM
rx7king's Avatar
Re: Re: Re: polycaps???
k thanks, thats much better, maybe i was missing somthing, cuz on the last couple of builds, i dont recall pushing them through, but that helps thank you
Old 11-23-2003, 03:20 AM
nis.k.a.'s Avatar
nis.k.a. nis.k.a. is offline
Re: polycaps???
One thing also....as you mentioned you don't glue the polycap. It is enclosed. This design not only allows the wheels to mount to the model it also gives them the ability to turn.
nightmaR3Z
