Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 11-22-2003, 12:14 PM
FLsurfer21 FLsurfer21 is offline
Send a message via AIM to FLsurfer21 Send a message via MSN to FLsurfer21
Engine problems
Recently i have been experiencing a very big problem with my 1998 ford ranger extended cab. It has a 4 cylinder engine. For some reason when i press in the clutch to switch gears the engine revs up to very high rpms. Until i come to a complete stop or put it back in gear the engine will not stop reving up to full rpms. Please help me fix this problem. It is not a everyday problem, it happens about 1 time every 2 weeks. Post here or email me at [email protected]
Old 01-08-2004, 10:41 AM
odb93 odb93 is offline
Re: Enginve reving problem
Replace the throttle position sensor.
Old 01-21-2004, 07:58 PM
96xlt 96xlt is offline
I have a 96xlt and changed the TPS even when it tested good. At first it didn't seem to make a difference but haven't had any idle issues lately. it's about 35& and a pain to change
Old 01-22-2004, 07:39 AM
Re: Re: Enginve reving problem
What makes it so hard to change???
Where is it?
Go fast, turn left, repeat as necessary.
Old 01-31-2004, 11:15 PM
It's located on the throtlle body, which is a pain to take on and off. It's on the back close the firewall and windshield. There's an electrical connector. Once you get the throttle body off (4 bolts) the there are two screw holding on the sensor. I could not get these out even with a Hitachi cordless high power drill. I luckily was able to use visegrips to turn them very slowly. They were siezed up.
Answer to Reving Problems! mrpibsk8er '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 1 05-20-2005 09:51 AM
Motor Reving Problems cwlewallen '88 - '91 Civic | CRX | Wagon | Shuttlee 11 01-21-2005 07:35 PM
b20/vtec reving problems pr3 ecu low12s Engineering/ Technical 15 10-27-2003 05:43 AM
b20/vtec reving problem??? Pr3 ECU low12s '88 - '91 Civic | CRX | Wagon | Shuttlee 3 10-18-2003 10:43 PM
reving problem....help! travis_118 '88 - '91 Civic | CRX | Wagon | Shuttlee 5 10-03-2003 09:52 AM
