Old 05-19-2005, 03:41 PM
mrpibsk8er mrpibsk8er is offline
Send a message via AIM to mrpibsk8er
Thumbs up Answer to Reving Problems!
I had posted on here about my problem with my 92 hatch with a d15b reving by itself between like 1000 and 2000 up and down, up and down, but today I fixed it! the problem is this little spring thingy at the back of the throttle body. it's a little flat plate with two screws located under the tps(throttle position sensor), and you just take the plate off and screw the little plastic peice in with two fingers. screw it all the way in, till it stops. then you replace the plate and screws. But it's hard to get to, so you may have to take the throttle body off like I did, but you will need a new throttle body gasket if you do this. I hope this helps some of you out there with this problem.
Old 05-20-2005, 09:51 AM
showcivic96ex showcivic96ex is offline
Send a message via AIM to showcivic96ex
Re: Answer to Reving Problems!
hey my car dose the same... when i get time i will do it thx, for the post
96 civic coupe... bomex front kit + wide bodykit, lowered 2 in, no wheels, (wrecked! sitting in my driveway waiting for me to fix her)
92 civic cx hatch... lowered 17z, d16y8 w z6 tranny and p05 ecu... .http://www.cardomain.com/id/showcivic96ex
2007 honda FIT brand spanking new
1993 honda del sol Si just got it (july08) and she was beat up pretty bad
[email protected]
