Old 11-21-2003, 05:41 PM
yung1 yung1 is offline
96 cavalier ABS light
My ABS light came on and will not reset.I checked all the sensors with a meter all ck good I swapped the abs relay no help,I cked the brake switch meters ok.I brought the car to the dealer and he scanned the system and said the ebcm was defective codes 1276 and 1278.I purchased the componenet and replaced it still have the same problem.Any ideas...............
Old 11-22-2003, 03:41 AM
loco_k0pykatz loco_k0pykatz is offline
Re: 96 cavalier ABS light
You mean the BCM (Body Control Module).
Well he should have reset the fault codes in the ECM to clear it.
Old 11-22-2003, 08:26 AM
Re: Re: 96 cavalier ABS light
When the vehicle was brought to thr Chevy dealer he cleared what he said was 13 trouble codes,I assume most of these where caused by me pulling and checking connectors and sensors.Error code 1276 and 1278 kept coming back abd they said the ebcm or abs control module was defective.I paid 100 dollars for it at a local salvage yard....
Old 11-22-2003, 09:18 PM
Okay...so when you start the car the light comes on immiediatly? or some time later? Did you try to skid the car to see if the ABS still works?
Old 11-22-2003, 10:44 PM
Immediately abs light comes on and yes I tried many times to skid car ,the abs system is disabled .I also removed the positive lead on the battery and let it sit for at least 30 minutes all no help....
Old 11-22-2003, 11:52 PM
check the right front and left front ABS wheel speed sensor wiring harness for damage resulting in an open circuit. The wiring harness may be damaged a few inches above the connector so check carefully. That would do it
Old 11-12-2005, 06:45 PM
94VL 94VL is offline
There are 2 sensors in the rear as well.Those could be bad too.
96 Cavalier ABS Light spazilla Cavalier 2 11-12-2005 06:42 PM
97 Cavalier ABS light on safe to drive? Kansas88 Cavalier 2 03-21-2005 06:40 AM
94 cavalier abs light azcardinals80 Cavalier 5 11-11-2004 09:02 AM
'95 Z24 Cavalier ABS Light & Check Oil eder91 Cavalier 2 11-04-2004 12:53 AM
'93 cavalier. ABS light comes on. Troubles Starting the vehicle cecile0918 Cavalier 8 05-26-2004 06:50 PM
