Old 10-26-2004, 06:13 PM
azcardinals80 azcardinals80 is offline
Question 94 cavalier abs light
i recently brought a 94 cavalier when i took it off the lot the abs light would come on and stay on even as i was driving so i checked the brakes and put new brakes on the light hasnt been on for quite a while like 2 months then the other day the light came on so i let it go cause the brakes are brand new and the hoses are good well need less to stay i was in the burger king drive though and the car died i got it goin again by a jump the light hasnt come on since.
can anyone tell why its doin this?
Old 10-26-2004, 09:33 PM
shimmy shimmy is offline
wait what?
Old 11-06-2004, 03:32 PM
nabeshein nabeshein is offline
Re: 94 cavalier abs light
The ABS light doesn't apply to the brakes, as you would think. It actually means "Alternator Battery System". (I have a 93 Cavalier with the same problem) You had a weak connection to your battery and it died from lack of charge. When you jumped it, it made a good connection again with your battery and the light went off. My best suggestion is to clean the bolts with a wire brush and make sure they're in tight.
Old 11-09-2004, 04:23 AM
achevygril achevygril is offline
Send a message via MSN to achevygril
i have a 94 cavalier and when im decelerating like off of a freeway, my car suddenly dies on me and the abs light comes on,
Old 11-11-2004, 03:51 AM
Cam7 Cam7 is offline
The ABS light means Anti-Lock Braking System. Does the light come on while you are sitting still or does it come on while you are driving? If it comes on while you are driving probally a wheel sensor. You have to have a Scan Tool to access the ABS codes. If the Light is on the system is deactivated. If the Light comes on while you are not moving not have driven it is more serious. Does your Cav have rear disk or drums sometimes if you have drum brakes the linning gets worn and will throw a code.
Old 11-11-2004, 09:02 AM
Fireplug Fireplug is offline
a 1994 has abs anti lock brakes
Wheel sensor or the motor pack by the master cylinder, I have replaced thousands of each of the.
Get the code read before you do anything else
