Old 11-21-2003, 04:36 PM
idrisn idrisn is offline
Need Help: Alternator & Alternator Belt issues
Anybody have any tips on replacing the belt and alternator on my 97 Metro?
I can't seem to get it to not squeek. I've had 2 alternators die and several belts shread and break.. presumably because of this issue.
Old 11-21-2003, 05:03 PM
metromitch metromitch is offline
Re: Need Help: Alternator & Alternator Belt issues
I would guess the drive pully is not fully aligned with the other pullies
on the same belt. Some times there is a little play in the body of the
alternator when the mounting bolt is slack. Make sure the alternator
is fully lined up before tightening the mounting and adjusting bolts.
It is possible you killed your alternator by overtightened. I would
expect this to lead to a bearing failure in the alternator drive.
Then I would drop it, get some rims and a nice tailpipe. Add a
chrome shifter and some Toyota Racing stickers and you'll be the
envy over everybody on the block!
Old 11-22-2003, 12:11 AM
geozukigti geozukigti is offline
Yeah, it does sound like you're over-tighetning it. When you tighten the belt, you should be able to push the belt with 1 finger, so it flexes 1". That's how I usually tighten mine. Could also be a bent or loose water pump pulley, or main pulley.
Anyone Ever Change Serpentine Belt & Alternator 2000 Focus Zetech??????????? marathonman10 Focus | C Max 5 02-12-2011 05:53 PM
Whiring & Whining sound on my 2003 Envoy 170KM washind Envoy 7 03-31-2010 08:25 AM
Need help: Bare Metal Foil issues Nutsforcars Car Modeling 3 08-23-2006 12:53 PM
Need help: Change 98 Malibu alternator wayfifty Malibu 2 09-25-2005 11:06 PM
alternator drive belt issue drock59 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 2 06-16-2005 01:30 AM
