Go Back   Automotive Forums Car Chat > BMW > 3 Series
Old 11-21-2003, 04:35 PM
Zenogias Zenogias is offline
Problems replacing the engine of a 1977 320i
Hello, 4 months ago, because of a moronic mistake, the engine in my 1977 320i cracked. I put cold water in a hot engine.. yea yea, i was stupid. Anyway, Eventually i got the money to buy a new engine for it, i had a mechanic put it in, but theres a problem.
for some reason, the fuel system isnt working. Fuel isnt getting to the engine at all, all the fuses and the master switch/relay are working, the car turns over fine, it just wont start cause no gas is getting to it.
Does anyone have any ideas as to why this would happen? Thanks in advance for any help you can provide!
Old 11-21-2003, 10:18 PM
KC Ron Carter KC Ron Carter is offline
1977 fuel system
The furl pump relay must get a signal from the ignition to activate.
Old 11-22-2003, 01:08 AM
Exclamation
Hmm..
I really didn't understand your response..
Could you go into more detail? the schematics you showed me dont make any sense.
Old 11-22-2003, 09:36 AM
Hmm,
To troubleshoot the fuel issue you must be able to follow a diagram.
The diagrams I supplied should be given to the mechanic who will fix the car.
Later,
Replacing the engine. Marlin39 M Bodies 8 03-11-2006 10:56 AM
Replacing the engine? rkuchar1111 Grand AM 1 01-26-2006 07:25 AM
worth replacing the engine? kennycu Bonneville 6 08-13-2005 03:16 PM
replace the engine 1,8 (K8) on 2,5 (KLZE) Romson MX-3 6 06-23-2005 07:30 AM
