Old 11-20-2003, 11:31 PM
Slacky Slacky is offline
Send a message via AIM to Slacky
b16 coolant problem
I have a coolant problem. My car overheats, and when I shut the engine off, tons of coolant leaks from either the radiator, or the lower hose.? What would cause this, water pump? what?
Please help, no one would answer in CRX forum, bastards.....
Brian
Old 11-21-2003, 02:58 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
are you sure its not leaking from the overflow canister line? maybe you just didnt attach it.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 11-22-2003, 02:02 PM
You mean the reservoir, no, it's leaking out of the bottom of the radiator, not the reservoir, I'm thinking the thermostat is stuck
Old 11-23-2003, 12:26 AM
michaelsd16c michaelsd16c is offline
So when your driving on the freeway or on the roads it overheats? Do you have a stock radiator? Now are you sure that it leaks from the lower hose>? I think that it's the radiator it self and not the hose. And if it is the radiator then your screwed. Meaning that you would have to get new/used radiator. Once it leaks their no real way of fixing it. Their is a temporaly way get some (JBweld). Do you smell coolant when your driving? I really don't think that it's the water pump because if it was then there wouldn't be a circulation of coolant.I sounds like you need to get a new/used radiator.
tell what you found.
Old 11-24-2003, 02:35 PM
tupacglock tupacglock is offline
Send a message via AIM to tupacglock Send a message via MSN to tupacglock
Re: b16 coolant problem
This seems kinda pointless to talk about, the radiator is probably the easiest thing to take in or out of your car, just unbolt it disconnect the hoses and fan, check them and it for cracks.
Old 11-27-2003, 03:07 AM
Re: Re: b16 coolant problem
Thanks mr. obvious, if its pointless don't post
Coolant/Over heating problem Poyntons Legacy / Liberty / Baja 8 03-21-2010 02:52 PM
2001 Chevy Cavalier Coolant System Problem getwilde Cavalier Problem Diagnosis 0 09-18-2009 06:43 PM
b16 engine problem help!!!!! B16CrX89 Engineering/ Technical 1 02-13-2004 07:54 PM
b16 swap problems b16sol '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 1 01-16-2004 08:11 PM
b16 swap problems b16sol '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 3 01-16-2004 04:57 PM
