Old 01-16-2004, 03:22 PM
b16sol b16sol is offline
b16 swap problems
hey i have a 93 del sol auto and i had a d16z6 and i pulled it out and i bought a b16a2, i have it in with one motor mount in the right spot and the other mounts are about an 1/8 of an inch off. i was told this motor would drop right in. was i told the right thing or do i need to do something to make it work?
thanx
joe
Old 01-16-2004, 08:11 PM
Plastic_Fork's Avatar
Plastic_Fork Plastic_Fork is offline
The motor drops right in if you've got a manual. The motor mount above the transmission on the automatic sits a bit higher than the manual mount. You need to get the B-series mounts anyway to hold the motor. Go get the B-series mounts and you'll need to remove the mount over the transmission and weld on the proper B-series transmission mount.
There's someone over on the Team Del Sol forum doing this very same swap on his automatic Del Sol. You may want to register there and go check it out for some additional information.
1995 Honda CRX del Sol VTEC
Manufactured: Suzuka, Japan
Production Sequence #1269
Team Del Sol member #1131
HondaVision: Team Sol Forum - Home of Team Del Sol
91 crx si w/ b16 swap, has problems, help me please jedmo91crxsi General Discussion 4 11-26-2006 11:19 PM
cv replacement problem crx w/ b16 swap italia7crx JDM Motor & Parts info/chat 2 04-08-2006 08:56 PM
b16 swap problem...any help? bobberbob '88 - '91 Civic | CRX | Wagon | Shuttlee 1 03-30-2004 03:07 AM
B16 swap problem please help! Aaron91ef9 Let's get Technical! 7 02-12-2004 06:54 PM
b16 swap problems b16sol '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 3 01-16-2004 04:57 PM
