Old 11-20-2003, 04:04 PM
ashah000's Avatar
ashah000 ashah000 is offline
Send a message via AIM to ashah000
reset engine light
How do i reset the engine light and get rid off the codes?
For Sale 98 Eclipse GS, 5 spd
Old 11-20-2003, 04:50 PM
aves911's Avatar
aves911 aves911 is offline
Massive Genius
Send a message via AIM to aves911
Unhook the battery terminal for a couple minutes and you'll be good to go. But I would get the code pulled so you know why the ECU triggered it. Ignoring unknown CEL's is not a good thing. Also, if you don't fix it more than likely the computer will throw the code again within a day of driving.
"this is a funnie thread..
we have a poser who keeps posting information that doesn't fit together..
and aves911 keeps correcting him"
Old 11-21-2003, 05:43 AM
ashah000's Avatar
How do i get the codes out off the system, after i fix the problem.
Old 11-21-2003, 07:10 AM
Zero8985's Avatar
Zero8985 Zero8985 is offline
Send a message via AIM to Zero8985
Re: reset engine light
After the problem is fixes, usually the codes won't be brought back up. When you fix the problem, the battery is normally unhooked anyways, so it get's rid of the codes. But if the problem is fixed, then the codes won't be brought back up again.
Old 11-21-2003, 11:16 AM
CODE4 CODE4 is offline
Send a message via ICQ to CODE4 Send a message via AIM to CODE4
the codes can be pulled off with a scanner (snap on sells them for a few grand I think) =] Dealership or full service shop should be able to pull them.
Old 11-21-2003, 02:41 PM
kjewer1 kjewer1 is offline
AF - Advisor
Every DSM should come with a bigass "www.vfaq.com" sticker right on the steering wheel. Go to that site, and click on "Retrieving Diagnostic Error Codes" under the Electrical section. On some cars there is a trick you do with the key to get the check engine light to flash the codes out. Some searching will find out what cars and how. I believe this is for the non turbo 2Gs. Also, if you have anyone local with a datalogger, they can all read trouble codes as well. If your car is a 2g, or any 95-96 and up car, it is OBDII. Again, dataloggers can get the codes, and some autoparts store chains (like Autozone) will pull the codes for you for free, hoping you'll buy whatever part caused the light (95% of the time its the O2 sensor )
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Check Engine Light..... Stinff Equinox 2 11-01-2010 10:15 AM
Radio**check engine light controls Impala____Chevy Impala | Impala SS 1 02-20-2010 10:44 AM
97 ram 4x4 shaking, check engine light on, one tire is wrong size cscafe Ram Pickup | Ram SRT10 2 11-18-2009 02:53 PM
Check engine light on 89 cherokee hoopdaddy6 Cherokee 3 04-09-2009 05:16 PM
grand am engine light? confuoco1 Grand AM 1 04-01-2009 04:06 PM
