Old 11-20-2003, 05:01 PM
atcaw94 atcaw94 is offline
Won't idle
I bought my son a 94 Eclipse GS and the idle drops down and the car eventually dies with the A/C on. Any ideas?
Thanks
Old 11-20-2003, 05:34 PM
KensEclipse KensEclipse is offline
Send a message via ICQ to KensEclipse Send a message via AIM to KensEclipse Send a message via MSN to KensEclipse
http://www.plymouthlaser.com/biss.htm
1991 Mitsubishi Eclipse GS-T
Old 11-20-2003, 05:48 PM
aves911's Avatar
aves911 aves911 is offline
Massive Genius
Send a message via AIM to aves911
Check for vacuum leaks as well. A bad PCV valve or cracked vacuum line causes our cars to throw fits when trying to idle. Also 1g's have problems with the idle control mechanisms in the throttle body. You can try manually raising the idle rpm by adjusting the BISS screw to see if that helps. I would suggest giving the engine bay a good once over to look for rotted vac lines, replacing the PCV valve ($5) and turning up the idle.
Should help dramatically
"this is a funnie thread..
we have a poser who keeps posting information that doesn't fit together..
and aves911 keeps correcting him"
87 Trans Am Starts but won't idle Sparkovac F-Body Problem Diagnosis 3 04-02-2010 12:00 PM
93 Rodeo cranks but won't idle. Help! hansola Rodeo | Passport | MU 1 04-13-2009 09:00 PM
94 Plymouth Voyager WON'T IDLE AHHH! Not EGR Not Idle Air Control HEELLLP! dadscarisaheadache Caravan | Voyager 3 03-28-2005 03:56 PM
plymouth voyager won't idle at times wteter Caravan | Voyager 6 01-08-2005 07:47 PM
