Go Back   Automotive Forums Car Chat > Mercedes-Benz > E-Class
Old 11-20-2003, 09:58 AM
PJSalerno PJSalerno is offline
85 190e annoying relay clicking
I have an annoying relay clicking problem coming from the glove box area. It's intermittent, but it seems to go away if the Heater-A/C is off. Anyone? Thanks...Phil
Old 03-04-2008, 12:28 AM
RESCUESERVCO RESCUESERVCO is offline
Re: 85 190e annoying relay clicking
YOUR BLOWER MOTOR IS GOING BAD (AMP OVERLOAD/OR SHORT)
Old 03-06-2008, 12:14 AM
frustrated101 frustrated101 is offline
That is the switching valve unit that operates your ac vent controls, it is has vacuum and electrical connections, it is fairly loud if you have no radio, dose all the vents seam to be working properly ?
Old 03-12-2008, 06:58 AM
Hattenator Hattenator is offline
frustrated is correct that noise is usually caused be the valves that control the air flaps or sometimes it is caused by the cabin temperature aspirator blower motor. This motor circulates the cabin air past a temp sensor for the tempmatic acc system
Old 12-26-2008, 11:42 AM
savordelli savordelli is offline
92 mercedes 190e 2.3 blower motor
i just now where is locate the blower motor because i had to change but i have no ideia where he is
Old 12-26-2008, 11:44 AM
please i just now where is the blower motor from my mercedes 190e 2.3
Old 12-31-2008, 01:46 PM
eclass eclass is offline
Check the aspirator blower and see if that is the noise. Located on the passenger side of dash. Take the lower panel down on that side of the dash and look/listen.
1989 Mercedes 190E OVP Relay yanceycat E-Class 0 11-30-2009 09:17 PM
No-Start when relays clicking - fuel pump relay? 2Bonnes Bonneville 5 08-24-2008 11:34 AM
main relay clicking crx hf '88 - '91 Civic | CRX | Wagon | Shuttlee 2 08-06-2004 10:51 AM
1999 Dome lights flicker / relay clicks same time 010175 C/K 3 07-01-2004 02:14 AM
