Old 11-19-2003, 08:26 PM
jake1964 jake1964 is offline
Send a message via AIM to jake1964 Send a message via Yahoo to jake1964
Angry Gm Truck Owners Sue Over Engine Noise
Check out this link and good luckwith the fight!!!
http://www.cars.com/news/stories/111...ory&aff=boston
Old 11-20-2003, 12:50 AM
TexasF355F1's Avatar
TexasF355F1 TexasF355F1 is offline
Send a message via AIM to TexasF355F1
Not sure what to think about it, but I'd really like to hear these peoples engine and see what they mean by "loud". But its definately not a good thing for Chevy. Maybe they'll take more time now in the R&D room.
*Under Construction - New sig to debut*
Old 11-20-2003, 06:59 AM
texasblueline texasblueline is offline
Re: Gm Truck Owners Sue Over Engine Noise
Here's a link to a website about the ordeal with an audio clip: http://www.pistonslap.com/photos.htm
Old 11-20-2003, 06:40 PM
TXAGG05 TXAGG05 is offline
Hey, BLUELINE,...does your '02 make the noise?...I'm worried mine will when it gets cold enough, or when I drive up to Taos where its really cold. I do notice a noise when I start it on some cold mornings, but it only lasts for about 10 to 15 seconds and even then I can't hear it in the cab, so I think its an alternator noise.
Thanks,
Jeb
Old 11-20-2003, 07:41 PM
99ssconv 99ssconv is offline
you can put 4 oz top engine cleaner in each cylinder (warm) and let sit for a few hours to disolve the carbon that is causing the rings to stick. additives in fuel are causing the noise, GM tech for 18 years.
Old 11-21-2003, 02:00 AM
Are you referring to my problem?...The truck has 31k on it so I'd rather not remove the heads if thats what it involves(since its under warranty) Do you think that is my problem and not Piston slap that is the talk of the town these days?
Thanks,
jeb
Old 11-21-2003, 06:35 AM
you put the top engine cleaner in through the spark plug holes, use a hose and funnel.
Old 11-21-2003, 08:49 AM
Mine doesn't make the noise that I can hear, or at least not yet. I bought the truck a few months ago and I'm also a little concerned about it making the noise when it starts to get colder. Maybe I'll go out this morning while it's still kinda cool and start it up with the hood open and see if I can hear anything.
Old 11-21-2003, 08:50 AM
For those of us who haven't noticed any noise (yet) would you suggest anything as a preventative measure, such as adding the engine cleaner in with your fuel once a month or something along those lines?
Old 11-22-2003, 07:48 AM
Lockjaw Lockjaw is offline
My truck has made the engine noise described since it has about 5k miles on it. I changed the factory oil at about 2000 miles over tofull synthetic, and have run it ever since.
I have complained every time my truck has been in for service, and have been told the noise is normal. I just wonder why normal noise was addressed and fixed in later models.
Personally I think it is pitiful that GM doesn't straighten this out. I have always thought my engine needed a valve adjustment. I have had the top end engine proceedure done, it helped but did not elimintate the noise.
I live in Alabama, and mine makes the racket for well over the first 1/2 in the morning (severe) and it makes racket all the time. Personally I have never heard of a new engine with a roller cam that made valve clatter that was normal, but I have been repeatedly assured that it is normal, and won't cause any problems.
That Nissan Titan is looking mighty sweet to me.
Old 11-22-2003, 07:38 PM
tooltimetech tooltimetech is offline
If it is valvetrain noise it could be as a result of a torn oil pump pick up screen o-ring, this will allow the oil pump to suck in air along with the oil and aireate the oil. This will cause valve noise on initial start up and then dis appear until the oil gets thuroughly aireated again. This is related to 4.8, 5.3, and 6.0 liter v8's. I have personally seen and fixed this concern and it makes a difference, the oil pressure still read good but did seem a little overactive when warm and after the engine had been ran at 2,000 to 3,000 rpm for awhile to aireate the oil. This concern has sometimes been overlooked because of all the noise that is considered to be normal so it gets shrugged off with a quick listen and a "yup it's a 5.3 (or 4.8 or 6.0)".
2005 Escape LTD - Engine Noise charettk Escape | Maverick | Escape Hybrid 8 11-05-2010 09:24 AM
'81 Deville 368 engine noise 83mb380sl Deville 2 10-17-2010 06:09 PM
1996 Avalon XLS Engine Noise Sarma Avalon/Pronard 0 06-22-2010 09:03 PM
99 Sunfire GT 2.4L Twin Cam Auto--CLICKING NOISES FROM ENGINE BLOCK E. Frank Cavalier Problem Diagnosis 8 07-28-2009 06:25 PM
90 Caprice lower engine noise? jomo3423 Caprice 4 04-18-2009 06:23 PM
