Go Back   Automotive Forums Car Chat > Mazda > B-Series/Bravo/Bounty/Drifter
B-Series/Bravo/Bounty/Drifter Bravo is the Australian vesion, Bounty the New Zealand version and Drifter the South African version.
Old 11-19-2003, 05:33 PM
tturney tturney is offline
Dome Light problems...
I have a '98 B4000. The problem is that the dome light, door ajar idiot light and warning sound don't work the way they should. the door ajar light stays on even when both doors are securely closed. the dome light sometimes doesn't come on when the door is opened....and more often than not, it won't go out when i park and lock it. the worst is when the dome light won't go off when i'm backing out of the driveway at night and it makes it impossible to see behind me. the light always goes off once i drive forward. all other times it's liable to do anything at any time. i've actually had to take out the fuse for the dome light because it would stay on for at least 45 minutes before i realized it was still on. any clues???
Old 03-02-2004, 04:25 AM
bladerunner52 bladerunner52 is offline
Sounds like a bad door switch - happened to my B3000
Old 03-03-2004, 08:22 PM
knotalot knotalot is offline
Re: Dome Light problems...
Every B series/ranger has this problem I think. Simple solution is to thoroughly spray the door latches with wd-40 while opening/closing doors. The switch(s) get gummed up and won't operate properly. Can be accessed by removing door panels but probably isn't neccessary. Lotsa luck
Old 02-15-2005, 01:19 PM
Re: Re: Dome Light problems...
Just to let anyone who has the dome light/door ajar idiot light problem. I found the answer on another site. WD-40 IS the solution. No need to remove door panels, etc. I sprayed into the latch area and all around. Overkill if anything. The problem went away immediately. It came back two weeks later so I sprayed again. That was almost 2 years ago. Never had the problem again.
Regards,
tturney
VERY Hot Dome Light hot dome light man Grand Prix 5 10-02-2010 11:11 AM
2002 Express dome light issue jtram2 Express | G Van 2 07-23-2010 07:57 AM
TIP: Fix those doorjam switches // no dome light... Intuit Escort 3 11-21-2009 10:27 PM
1997 thaoe\yukon dome light problems lodownlv C/K 3 05-05-2004 08:35 AM
Dome light problems CivicSpoon Grand AM 1 11-22-2003 10:35 PM
