Old 11-19-2003, 04:36 PM
STEVE-Z STEVE-Z is offline
Need Help on DOME OVERRIDE
Last week I had my 2003 Blazer valet parked at a garage in Philly. When I got the car back, the interior lights will not go out now unless I push the DOME OVERRIDE button back in. I know it should be out to allow for the automatic shutoff of the lights but I have to keep it in so the lights will go out. Any takers on this one??? Thanks
Old 11-21-2003, 09:10 AM
RABarrett RABarrett is offline
Re: Need Help on DOME OVERRIDE
The BCM normally controls the interior lights, receiving inputs from the switches and door switches. If the BCM sees a ground on this line, the lights will stay on unless overridden. Check all of the switches, by removing them from the door pillar. Disconnect one of them, after removing them and look for a ground on the wire. If it is grounded, look for a short. If not, try resetting the unit by disconnecting the battery for 10 minutes, then try again. It is also possible that the valet did something while in the vehicle to damage the BCM. Ray
Old 11-25-2003, 10:38 PM
show89 show89 is offline
same with mine
in my 89 blaze the dome light will not turn off for some reason even after you close the door .it does it sometimes whats the deal is yours like that or what
Old 11-26-2003, 01:38 PM
doctah doctah is offline
mine did that (98 Blazer)...
Drove my alarm batty. The pin switch (not sure of the actual name) on one of my doors wasn't connecting properly. I twisted it - and it worked.
I have an aftermarket alarm - so I'm not sure if my situation is the same as yours.
Old 11-26-2003, 05:55 PM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
Not to sound dumb but did you try setting the dimmer switch? Maybe he turned it all the way up for some reason? In my '02 Silverado you can do that. I also have those push button lights on the overhead console that my kids like to press. Those stay on unless you press them again. I know in my '95 S-10 I had a switch that got bent on the driver's side. It was replaced under warranty. It was located on the bottom edge of the dash. I think the newer S-10 are different though.
Old 11-26-2003, 06:18 PM
My message from the ground on the door switch wiring is the same as the one from doctah. Grounds on this line, for any reason will cause the BCM to leave the lights on. Ray
Old 11-27-2003, 07:09 PM
Brokebyford Brokebyford is offline
I had the same problem but my light would just pop on sometimes and would not go off.It turned out to be the switch on the light on the interior rear in the back was bad.I put a piece of tape over it with the switch in the off position as a temp fix and the problem was solved.
Old 12-04-2003, 01:53 PM
frankjc frankjc is offline
i've had the same problem a few times.
what i did was open the doors one by one, and wiggle the switch, till the light went out. it has happened a couple of times, i suppose someday i should change the switches.
I need help!! Cade.Garrett Car Buying Q&A 1 06-04-2009 07:07 PM
dome override malfunction northshoreyukon Yukon 5 02-25-2008 01:21 PM
Dome Override Button Evansamms Silverado 4 11-26-2007 09:36 AM
Dome Override SComp23 Blazer 4 02-20-2005 12:14 PM
Need help replacing headlamps and dome light lamp on '98 Escort Sport ChaplinXIV Escort 5 02-22-2004 12:14 AM
