Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse 2000+
Old 11-18-2003, 09:18 PM
Jaguar3407 Jaguar3407 is offline
Send a message via AIM to Jaguar3407 Send a message via Yahoo to Jaguar3407
need help with my Eclipse GS
ok i have a Eclipse GS and i want 2 put a V6 out've a 300zx or mayber some other car i just wanted 2 know what u have 2 say about it thnx
Old 11-21-2003, 06:43 PM
1gkiller 1gkiller is offline
Re: need help with my Eclipse GS
no dont do it.......your motor has potential especially if your going to spend that money on doing that swap.....redo the motor...low compression pistons, rods, bearings, head work, fuel management and a t3/t4 turbo w/ all hardware... one love
Old 11-25-2003, 10:23 PM
johnnyBgood johnnyBgood is offline
Send a message via AIM to johnnyBgood
The 4G64 takes boost very well. The stock compression is low enough that adding boost is not a problem. the compression ratio is 9.4:1. Pretty good. One guy i know has actually raised his compression by adding 10:1 forged pistons and then boosting and he has the highest whp 4 cyl 3G in the country. 316 whp on 14 psi. And raised his boost to 20 psi with no issues. then he got ran off the road and his tranny got a hole ripped in it. But he had alot of motor work done.
First thing would be to tune the car to get a proper AF tuning session. the stock tune runs pig rich. You can get probably another 10 whp out of just that.
The rods for the 4G64 are out of the 2G eclipse 4G63 turbo good for up to 25 psi (but i would not do that). Point is, you can run up to 11-12 pounds of boost on the stock engine, currently being done with the RippMods SDS stage II with an expected dyno of 290 whp. I am figuring for maybe between 270 and 280 whp. In reality with that much power, traction becomes a major issue.
FYI, there is a company out of south FL that makes a turbo kit for the 4G64. At 8.5 psi on a stock engine, their kit lays down 264 whp/284 wtq. Accelerated Autosports. http://www.acceleratedautosports.com
Old 12-11-2003, 12:35 AM
flatout30 flatout30 is offline
exhaust
Does any one know anything about the Tsudo N1 exhaust.
As for as I understand it's a knock off of the A'PEX but is it of the same quality
Need Help with Eclipse 5331 Security Madasljj Car Audio 9 08-01-2012 10:52 AM
Need help with 2000 Eclipse GS MitsuRider Eclipse 2000+ 2 10-20-2005 08:48 PM
I Really Need Help With My Eclipse teamsevenseclipse Off-Topic 43 06-17-2004 10:24 PM
