Old 11-18-2003, 08:12 PM
Dumped91Hatch's Avatar
Dumped91Hatch Dumped91Hatch is offline
Hurst Short Shifter?
I was just wondering how many of you are using this shifter? I found it in JC Whitney S.C. for $50 but it doesn't come with bushings, bearings, or a base plate. Is it okay to use this stuff from my car since it only has 42,000 original miles on it?
Check out my car here My 91 Hatch
Old 11-18-2003, 08:16 PM
BullShifter's Avatar
Re: Hurst Short Shifter?
I have the Hurst & it works fine - I did install the bushings for $10 - well worth the $$$$
Why wouldn't it be ok to use? I would install a short shifter with only 1,000 miles
Old 11-18-2003, 08:42 PM
I meant would my bushings and bearing be okay to use?
Old 11-18-2003, 11:48 PM
Re: Re: Hurst Short Shifter?
My bad I thought you meant stabalizer bushings - get some poly ES or Prothane!
Yes it should be fine to use, just transfer everything over. Make sure to lube well & keep clean during the process.
Old 11-19-2003, 12:12 AM
Kool thanx
Hurst short shifter removal? ikeyballz Camaro Discussions 5 10-07-2006 09:07 PM
where can i find a short shifter with bronze shifter brushings to make for nice, tigh limer MX-3 1 03-31-2005 04:35 PM
short shifters... jcl603 General 10 07-11-2001 01:49 AM
