Go Back   Automotive Forums Car Chat > Cars in General
Old 11-18-2003, 06:24 PM
timmie2508 timmie2508 is offline
Wheel Question
Ok i have 16 inch tires on my car. I was wondering if 17 inch rims would fit on my 16 inch tires? Is there anyway to make this work?
Old 11-19-2003, 01:41 AM
BullShifter's Avatar
Re: Wheel Question
Yes usually you can increase the rims size. This is called plus sizing - rim gets bigger / tire side wall shrinks. You'd be better off posting in the correct section . . . check out www.tirerack.com or www.whalentire.com for helpful tire spec's - will tell you what your speedo will read with different size tires. Remember the tire sidewall is the 1st thing to absorb bumps. So the less there is, the more you feel inside.
96 Eclipse 2.0 Manual Wheel Bearing Question AdrianT Eclipse Problem Diagnosis 1 09-20-2010 08:05 PM
14 inch olds wheel question- help! lakesidebluexpy General Discussion 1 12-22-2002 05:48 PM
240 wheel questions TEIN240 Tires and Wheels 2 10-11-2002 11:21 AM
18 in. wheel question... Nismoboy1 Cosmetics 2 12-18-2001 01:45 AM
wheel question Shobo General 2 09-25-2001 07:37 AM
