Old 11-18-2003, 05:10 PM
D16Y4civic D16Y4civic is offline
Exclamation tap tap taparoo
Just wondering why my engine when at idle you can here this slight tapping (tic....tic....tic) now Ive been told that this might be a lazy tapet from over revving of the engine and it needs the timing looked at I was just wondering if anyone else gets the same thing happening to there engine??
Old 11-18-2003, 08:12 PM
i_a_n112784 i_a_n112784 is offline
Send a message via AIM to i_a_n112784
Sometimes tapping is caused by the valves. They often need to be adjusted every 30k. I don't know what they need to be adjusted to for your car, but they are fairly easy to adjust. It just involves taking off the valve cover, and using a wrench, screwdriver and a one of those spark plug gapping gauges (brain is having one of those days where you cant remember jack)
tap tap thump THUMP CLANKACLANK - Supercharger Woes Mr. Cynical Grand Prix 2 11-12-2003 09:43 PM
How to tap into my fuel line? 96camarov6 Camaro Discussions 0 11-30-2002 06:57 AM
I finally installed my reverse indiglo's, but I tapped the dimmer wire...no problem? tenguzero Accord/TSX/Accord Hybrid 1 07-30-2002 08:15 PM
cold engine start tapping noise??? tim-may Maintenance 2 02-24-2002 09:42 PM
increase headlight wattage by tapping into battery? dchien Cosmetics 0 08-15-2001 05:39 PM
