Old 11-18-2003, 08:48 AM
new2blazers new2blazers is offline
99 Blazer A/C controls
I just bought this Blazer recently and now I'm finding all the problems.
When I bought it, the controls all worked. Now, the flow never changes from the vents no matter what position you put the controls in... (A/c, defrost, heat) the air always comes out the dash vents. The heat is hot and the air is cold like it should be. Does anyone have any ideas?
Thanks form a newbe...
Old 05-09-2004, 04:57 PM
JasonJeardoe JasonJeardoe is offline
I had the same problem, and it was the selector switch itself. A new one is 125$ at a dealership. So I tore mine apart and a rubber diaphram was leaking air, so i put a washer behind it to give it support. Does it sound like hissing air under the dash? If it does that is probably it.
Old 10-21-2004, 01:28 PM
LukeBickers LukeBickers is offline
Re: 99 Blazer A/C controls
mine is definitely hissing from the rubber diaphram. where did put the washer behind? i can't see where a washer would give any support to the rubber diaphram.
94 s10 blazer 4wd 4dr 4.3 parting out chevyshitsonford Classifieds 9 10-27-2016 09:35 PM
97 Blazer idle air control valve test mansopoor Blazer 5 02-05-2011 04:51 PM
94 s10 blazer 4.3 high oil pressure chevyshitsonford Problem Diagnosis 4 03-08-2009 09:11 AM
PROBLEM now 98 blazer 4.3 v6 just replaced fuel pump smiley24 Problem Diagnosis 7 02-26-2009 10:45 AM
98 Blazer w/climate control- intermittent AC DaWa Problem Diagnosis 3 06-12-2008 11:20 AM
