Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 11-18-2003, 08:20 AM
ckpaas ckpaas is offline
special tools for the northstar 4.0L
I run onto this..
http://toolcraze.com/Merchant2/merch...gory_Code=spec
Edit: I wont be buying any special tools unless I have to.. Most parts stores rent them or just charge a deposit for them..
Old 11-18-2003, 12:05 PM
Indy8's Avatar
Indy8 Indy8 is offline
Re: special tools for the northstar 4.0L
You do need that for water pump replacement. However, Lisle Tool Co. sells the same thing for $24.95 through special order at any Pep Boys store.
Old 11-18-2003, 03:19 PM
bustedratchet bustedratchet is offline
Re: Re: special tools for the northstar 4.0L
115.95 for that ! there nuts I got mine from Snap-On for about 45.00.
Old 12-12-2003, 12:27 AM
KB5556 KB5556 is offline
I am a new member on this forum and have already found your information useful - THANKS
But, I am wondering about the quality of these various manufacturer's
The Lisle seems to be the weakest tool of the bunch, will it really do the job? Or, do you just get what you pay for?
I would never question snap-on quality but had to e-mail snap-on to request more info since it's not possible to find though their on-line store without the P/N S6192A and now goes for $74.45 which still seems a little high
I wouldn't even consider ToolCraze at that price!!
But I have also found it through JC-Whitney SKU 49ZX0424N $39.99 and at least it looks like a forged tool as opposed to the Lisle
?? Anybody have any actual experience with any of these ??
Also Snap-on lists a stabilizing strap P/N S6192A-1 for another $20.80 - Anybody recommend this/is it necessary?
Old 12-12-2003, 01:41 AM
Indy8's Avatar
How many waterpumps do you plan on changing? While I have never bought this particular tool, I have never had a Lisle piece fail on me. Quality steel, and made here. Their specialty products are a very good value. Most of my stuff is Snap-On, with a few Craftsman mixed in.
Quality isn't expensive, it's priceless.
Old 12-12-2003, 10:11 AM
I'm not a pro mechanic - just a mechanically inclined owner who doesn't like wasting money through dealer repair centers, or on buying crappy tools. I need this soon to do my 97 Aurora, but I am also leaning towards a future purchase of a Caddie - so I'll need it to last.
And on a different but related issue, maybe you can answer this.
The factory manual diagram shows an "o-ring" for the pump, but doesn't list replacing it in the procedure. Which I would think would be common sense. Does the pump come with an o-ring and does it require a special tool for installation?
Also - it doesn't show in the diagram - or mention in the procedure a "gasket" for the pump cover . Online stores list the pump as being sold with a "gasket" Is there a separate gasket for the cover or is the online reference of a gasket actually referring to the o-ring?
Old 12-12-2003, 01:16 PM
Indy8's Avatar
I've never done mine, but most aluminum to aluminum applications only require an o-ring that sits in a machined groove and no sealant.
Old 12-13-2003, 05:41 PM
mike98c mike98c is offline
I bought and used the Lisle tool. It is just stamped. The female socket end distorted the metal slightly trying to break the pump loose where it is welded to the body. I ended up warming the pump but I don't remember if I used a propane torch or boiling water anymore to loosen and rotate it loose. Yes it is an o-ring set into the block that seals the pump to the block.
Old 12-13-2003, 06:14 PM
By the way turn the pump CLOCKWISE to unclock the pump from the block.
Old 12-13-2003, 07:44 PM
Indy8's Avatar
So is the tool good for another job later, or would you recomend paying double for a better one?
Old 12-14-2003, 09:56 PM
The distortion didn't make the tool unusable but if anyone has a pump that's been on there for a while (mine had 130,00 miles on it but only four years) I'd spring for a heavier duty socket.
Old 12-25-2003, 12:56 PM
coololman coololman is offline
how much pressure do you apply to this silly thing,I just bought one of these sockets for 27.oo dollars at brady`s discount tools & so far I caint Git It Off
Old 12-25-2003, 11:53 PM
Indy8's Avatar
Use a propane torch.
Old 12-26-2003, 08:28 AM
ok,hers the scoop.heat it up about 15 min.with a propane torch,make sure your socket is flush & seated,use a short cheater bar & start rocking pressure into it clockwise untill it pops.it took a lot of pressure,i thought i was going to break the socket first,but its a done deal.lots of luck,,,,,,,coololman
Old 12-27-2003, 06:41 PM
Thanks,,,,,,indy 8
Cars for the Cure 2009 Pictures Pastapuck Car Shows 0 02-11-2009 10:45 PM
Stock Compression Ratio for the '02 4.0L? Kuhn Wrangler 1 08-19-2007 06:34 AM
Question About Special Tools for Idler Arm Installation Tigerhaze S-10 3 05-20-2005 08:21 AM
Specialized Tools for Head Gasket Replacement JTFlorida 3 Series 2 04-18-2005 08:00 PM
special tool for ecu pins pm5 '88 - '91 Civic | CRX | Wagon | Shuttlee 2 10-24-2003 08:47 AM
