Go Back   Automotive Forums Car Chat > Honda > CL | Inspire | Saber | TL
Old 11-17-2003, 02:27 PM
drodavis drodavis is offline
'99 3.2 TL...FUSE out?
Within a half hour, two wierd things happened:
The 'brake light' warning light showed up, and the 4 way switch that controls both side mirrors stopped working in the UP direction. All other directions seem to move perfectly. Neither side mirror will move up.(The switch 'toggles' just fine.) In addition, we can't find a brake light that is malfunctional.....Are both problems really one fuse acting up, or do we really have two different problems....The owners manual is not really clear on the fuses.
Anyone have an idea?
Thanks,
Drodavis
Old 01-03-2004, 06:53 PM
imtoplaya imtoplaya is offline
Send a message via AIM to imtoplaya
Re: '99 3.2 TL...FUSE out?
Check under the hood in the fuse box...if you look under the lid that covers the box it should tell you what fuse goes to what...i have a 96 tl but i think the fuse box is still labeled under the top. Good Luck!
Acura 3.2 TL Transmission robdial1 CL | Inspire | Saber | TL 26 05-23-2005 06:47 AM
The Acura 3.2 TL JD@af CL | Inspire | Saber | TL 11 06-17-2003 04:56 PM
Bolt pattern for Acura 3.2 TL Type S-Help chillinMax Tires and Wheels 2 05-24-2003 06:01 AM
1996 acura 3.2 TL Andreaalston CL | Inspire | Saber | TL 0 12-06-2002 10:12 AM
3.2 TL Starting Problem fredflint Engineering/ Technical 1 11-27-2002 12:42 AM
