Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 11-17-2003, 01:07 PM
laidback22 laidback22 is offline
Cool Engine swap 2.0...2.1
To swap from a 2.0 to a 2.1 in an 88 SI are there changes needed.
Different ECU...Intake...transmission???
Old 11-17-2003, 06:27 PM
GundamExpo's Avatar
GundamExpo GundamExpo is offline
Better idea would be to drop in a B20A. the B21A1 that you want to drop in tends to have problems burning oil, because of an experimental material used for the cylender sleeves.
Check out www.preludepower.com you can probably get more questions answered faster and more completely then you can here.
Old 11-21-2003, 01:15 AM
car_boy_16 car_boy_16 is offline
Re: Engine swap 2.0...2.1
lol I thought I was the only one refering people to www.preludepower.com ! lol, good advice man. Yeah, drop in a jdm b20a like he said, much better choice.
Old 11-22-2003, 09:57 AM
HondaIntegraXSI HondaIntegraXSI is offline
Send a message via AIM to HondaIntegraXSI
The JDM B21A had the same piston sleeve material that the B20A had. you are correct about the USDM though. I would take the JDM B21A3 because it has a higher comp ratio, 165hp, and 137 lbs of Tq. yes the stock tranny will work, no you will have to find a USDM ECU, and Intake manifold. I highly recoment a clutchmaster stage 1 or higher clutch with this swap.
Your V-8 can't touch this sweet Honda Integra XSi....
dakota engine swap jpuckett13 Dakota 0 08-23-2010 07:21 PM
2001 2.0 Jetta with 5 codes???? moemo '97 - '03 1 12-29-2009 05:22 PM
need vacuum diagram:'88 ram d-50,mitsu 2.0 liter cukoobajube Ram Pickup | Ram SRT10 0 05-31-2009 05:59 AM
97 Jimmy engine swap gsnats Problem Diagnosis 5 03-06-2009 09:40 PM
Nissan Quest V6 to 2.4 ltr 4 cylinder swap Scraped Knuckles Quest | Presage | Serena 4 02-20-2009 08:59 AM
