Old 11-16-2003, 11:06 PM
Jiffy Jiffy is offline
Question Stereo Installation Problem
I was trying to install my stereo system today, and on the back of my factory deck there was a long black cord attached, It went deep into the back of my dash, too far to follow, and it was pretty tight. Im thinking it was for the CD Changer, which is an option in these cars, but not sure... Any Idea's what this cord is and how to remove it?
Also, after hooking up my amp and sub, when i turn the lights on, the stereo turns off. When i open my drivers door, the interior lights never turn on...im wondering if that sensor would cause the stereo to shut off or that mysterious black cord?? All I really did was install the remote wire, ground wire, and power wire to my car. Please help!
Old 12-15-2003, 12:27 AM
talonspaz420 talonspaz420 is offline
Re: Stereo Installation Problem
if u find out what the problem is let me know have the same problem i just ran the new deck off the battery and pulled the sterio fuse
Old 12-22-2003, 06:38 PM
shekky shekky is offline
Banned
Send a message via MSN to shekky
try hooking that wire up to ground from the deck. that should solve it.
Old 12-27-2003, 07:41 PM
msgrntalon msgrntalon is offline
Send a message via AIM to msgrntalon
you might want to make sure you have everything grounded good, when i hooked up my amp i had a problem sort of like that, come to find out i did not have the amp grounded good enough.
Old 12-28-2003, 08:11 AM
diviniti's Avatar
diviniti diviniti is offline
Send a message via AIM to diviniti
that wire may be the wire to the factory amp under the pass seat (if your car is equipped with this)
to avoid this situation in the future, just buy a direct factory plug wire in harness. they are around $8.00 - $10.00. and if you really are not to sure on what you are doing, its the best cheapest way to not create headaches later down the road.
Old 12-28-2003, 10:49 PM
thepyrofish thepyrofish is offline
ummm, long black cord?...probably the antenna wire, if the end is a plug(looks kinda like a mini cigarette adapter) it is antenna
Old 01-06-2004, 04:56 PM
bighauns's Avatar
bighauns bighauns is offline
Send a message via MSN to bighauns
in regards to the lights dimming....I had the same problem in my talon when I installed my stereo. All it was that I blew a fuse down by my feet...I believe it was the one called "room" or "cabin" or something like that! hope it helps
Old 01-14-2004, 10:31 PM
Nephest's Avatar
Nephest Nephest is offline
Send a message via MSN to Nephest
Hey i have a similar problem. I hooked up my cd changer and now when i push my ECM/Power button by the shifter, my dash lights come on? Do you know why that my be?
96 Olds Stereo installation problems wwepatriot Car Audio 22 08-10-2010 08:44 PM
new stereo install problems karmacae Interior 11 12-30-2007 06:21 PM
Stereo Installation - problem with instrument panel lights Longmark999 Rodeo | Passport | MU 11 10-06-2007 05:40 PM
1988 Century stereo installation problem jameslinkinpark Century 3 09-05-2007 05:41 AM
2003 malibu stereo installation problem sunic Malibu 1 02-25-2006 10:12 PM
