Old 08-06-2010, 02:58 PM
wwepatriot wwepatriot is offline
96 Olds Stereo installation problems
First off, this is the wiring schematic for the 96 olds cutlass ciera;
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 3 1/2″
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: 6″ x 9″
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Now trying to install a Dual XD1222 60 Watt CD receiver into this has been a pain.
First off some of these wires control other things in the vehicle such as power locks, console lights, overhead lights in the interior and trunk.
What I have managed to do is some how get the CD player and all to working, but the odd part is, I have to turn on the headlights to get the sound to come on, I can turn the lights off and it stay on, I can turn the radio off and back on and the sound will come on still, but some loose wires remain and I am only able to get front speakers to working.
Problem has been trying to what color goes where since the colors on the CD player wiring are different than that of the Car wires itself, so matching up colors dont exactly work.
any suggestions?
Old 08-06-2010, 05:35 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
Re: 96 Olds Stereo installation problems
take the wire you have connected to the
Old 08-06-2010, 05:37 PM
Audio Guy
take the wire connected to the car's gray illumination wire and connect it to the car's yellow switched voltage wire.
Old 08-07-2010, 11:41 AM
do you know where the wires on the Dual Stereo go to the wiring on the car? outside of the gray illumination wire?
Old 08-07-2010, 12:22 PM
OnThePike
Guest
Posts: n/a
This should take care of your wiring issues:
Old 08-07-2010, 02:39 PM
that part was in the manual, its the easy part, the hard part is the speakers and its wiring. Like I said, some of the cars wires control other crap when connected like overhead lights, dash lights, trunk and hood lights, and the sort.
Old 08-07-2010, 03:02 PM
OnThePike
Guest
Posts: n/a
I don't understand. The speaker wire connections are included in the manual and you already have the speaker wire colors for your vehicle. Once you have the speaker wires connected correctly, there are only a few more left. You're not going to use all of those wires with the new radio.
For other wires that the radio cannot control, simply bypass them. This would involve cutting the harnesses and direct wiring the radio, while maintaining the circuit of each non-used wire. Or, you could get an aftermarket harness adapter. Crutchfield usually has them all. But there are other places to get them, probably at a cheaper price also.
If the speaker wiring controls something else, you could direct wire new lengths of speaker wire, which is an involved process requiring panel removal, possible rug lifting, etc.
If none of this helps you, then I still don't understand your issue.
Old 08-07-2010, 07:23 PM
Audio Guy
wwepatriot - have you ever wired up a car stereo from scratch like this ?
maybe you need a wire to wire chart ...
Old 08-08-2010, 09:19 AM
nope, this is first time, I think I got everything figured out though, got it all working where I dont have to turn on headlights to get it to working. That gray illumination wire made all the difference.
Old 08-08-2010, 07:39 PM
Well one minor problem is, the radio has no memory like clock, it always resets when turned off. Lights like overhead, trunk, only come on when either the car is on, or engaged where everything works off battery.
Old 08-08-2010, 08:10 PM
OnThePike
Guest
Posts: n/a
Connect "Car Radio Battery Constant 12v+ Wire: Orange" to "5A Fused Yellow Memory" lead from the radio. Or anything connected directly to the battery that is always on even when the car is not running. Make sure it's fused.
Old 08-08-2010, 08:59 PM
Yellow Wire (only 1) is connected to the orange wire, its the only way the Radio powers on in any capacity.
Old 08-08-2010, 09:31 PM
OnThePike
Guest
Posts: n/a
No, that shouldn't be correct. You have two power wires from the car and two power wires from the radio.
Car Yellow Wire to Red Radio Wire.
Car Orange Wire to Yellow Radio Wire.
Try that and report back.
By the way, all this advice is solely based upon your initial post. If the below isn't 100% correct, neither will the advice given.
Old 08-09-2010, 06:23 AM
That is how its currently setup now.
But the way it was was that it wouldnt power on if the red or yellow was not connected to the orange, both are connected to it. I think theirs another Car Yellow connected to the Orange, Red, and Yellow as well.
Old 08-09-2010, 02:08 PM
OnThePike
Guest
Posts: n/a
Have you checked both fuses? The 5 amp fuse on the radio lead, and the radio fuse in the cars fuse box?
