Old 11-16-2003, 11:01 PM
MReyes6 MReyes6 is offline
Send a message via AIM to MReyes6 Send a message via Yahoo to MReyes6
95 S-10 Clutch
Anyone know what could cause a clutch to occasionally fail? It seems that occasionally I have a really soft clutch, and at other times it's normal. I am assuming that there is air in the line, and have continuously been bleeding the line(Hydraulic clutch system). The entire system has been replaced from master cylinder to the plate. It worked fine for a while after being replaced, and just recently started to do this. Any suggestions? Thanks for any help.
Mike
Old 11-24-2003, 07:02 AM
98taurusse 98taurusse is offline
Re: 95 S-10 Clutch
have you replaced the clutch fork???? Sounds almost like it is bending the fingers on the pressure plate and causing your uneven clutch. Had problems on my 1995 s10 I eventually changed the transmission. Still having problems with mine eating throwout bearings......
Leon
Old 11-25-2003, 04:54 PM
FRS2004 FRS2004 is offline
Re: 95 S-10 Clutch
Sometimes a clutch could exhibit this behavior if extremely hot. Does this only occur after a great amount of shifting or shifting with an excessive amount of slip>
95 s-10 clutch problems brmcdan1 S-10 2 08-19-2006 11:24 AM
s-10 clutch bleeding problem trave S-10 4 06-03-2006 10:18 AM
1999 s-10 clutch problem Tony76 S-10 3 01-08-2006 12:31 PM
99 S-10 Clutch (won't Go In Gear - Pedal To Floor) bhcbob S-10 1 12-11-2003 07:56 PM
89 Chev Blazer S-10 Clutch Dan V S-10 1 11-16-2003 10:48 PM
