Old 11-16-2003, 05:57 PM
johnbu johnbu is offline
Check Engine Codes Specifics
Sorry if I missed this information posted elsewhere, but I did try to find it. I am looking for specific instructions on how to read the check engine codes in my 1997 Chevy Cheyenne, C/K pickup. 1500 series, 5.0L, automatic.
Can they be read without using a computer? If so, can someone tell me how. I was told the ignition switch can be flipped a certain number of times to get the codes to be displayed. Is this correct?
Any help is appreciated.
Old 11-18-2003, 12:16 PM
RABarrett RABarrett is offline
Your system is OBDII specific. That means that a scanner of some kind is necessary to read and specify the codes involved. You will not need a GM dedicated unit to read the codes, just one dedicated to OBDII programming. A GM scanner will assist you in other functions regarding the problem, but knowing which code is set will not require a GM scanner. Ray
Old 11-18-2003, 05:25 PM
Re: Check Engine Codes Specifics
Thanks for the clarification on this...
Old 11-19-2003, 02:35 PM
prankstar prankstar is offline
my 1994 truck can be tested without a scanner, but I think it might not be a OBDII. Probably the earlier OBD, but in mine you can jump two of the connector pins and it will give you trouble codes.
Old 11-19-2003, 02:49 PM
UngerC UngerC is offline
I believe that OBDI when to OBDII in 95 or 96. I have a 97 and it is OBDII you can get a reader and save lots of time
Check Engine Light..... Stinff Equinox 2 11-01-2010 10:15 AM
97 ram 4x4 shaking, check engine light on, one tire is wrong size cscafe Ram Pickup | Ram SRT10 2 11-18-2009 02:53 PM
1998 Malibu - check engine light jpar1983 Malibu 2 10-28-2009 07:49 PM
Check engine light on 89 cherokee hoopdaddy6 Cherokee 3 04-09-2009 05:16 PM
1994 Ranger 4cyl check engine light/ABS light wont start on cold mornings 94rangerproblems Ranger | Courier 1 03-21-2009 06:40 AM
