Old 11-16-2003, 06:40 PM
4thGen4Door's Avatar
4thGen4Door 4thGen4Door is offline
Girlfriend forgets to turn lights off, need help
My girlfriend has forgot to turn the lights off on the car 2 times this week and keeps killin the car. How can I have the lights turn off auto if she leaves then on again. I have It hooked up so It would beep but that just stoped working after my alarm was installed. Thanks Terry
Old 11-16-2003, 06:49 PM
dxhatchback dxhatchback is offline
Re: Girlfriend forgets to turn lights off, need help
give her a good slap next time... like a tru pimp.. i bet she will never forget again
Travis
HONDA is the BOMB!
Old 11-16-2003, 07:47 PM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
Either hook up the alarm correctly or go to parts store and buy an aftermarket buzzer.
Old 11-16-2003, 08:04 PM
BullShifter's Avatar
Install a headlight buzzer : http://fourthgenhatch.com/headlightbuzzer.html
I suggest using a connector meant to plug into the fuse socket instead of jamming the wire & fuse in, which may make the fuse loose some day.
Old 11-16-2003, 09:23 PM
H4Bangin's Avatar
H4Bangin H4Bangin is offline
Send a message via AIM to H4Bangin
Re: Re: Girlfriend forgets to turn lights off, need help
Travis
Old 11-17-2003, 08:16 AM
Thanks, I bet the fuse just came loose I will need to take a look. If not, is they some thing I can install that will turn them off 4 me? Like on the Bmw cars.
Old 11-17-2003, 09:43 AM
Masta's Avatar
Masta Masta is offline
Send a message via ICQ to Masta Send a message via AIM to Masta
just let her learn her lesson. i used to leave my lights on before, but after awhile, i got used to not leaving them on and bam, no more problem :P
Old 11-17-2003, 12:49 PM
Re: Re: Re: Girlfriend forgets to turn lights off, need help
You know what, I'm sure there is some kind of aftermarket timer for turning lights off. Where you get it, I have no idea.
Old 11-17-2003, 01:46 PM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
Get a new girlfriend.
Just kidding.
There's probably a good way to rig up a buzzer so that if the ignition is turned off and the lights are still on, it'll beep or buzz to warn of the situation...
Actually, I think I've seen a how-to on it before...
Yep, here it is:
http://www.fourthgenhatch.com/index2.html
Old 11-17-2003, 04:00 PM
Setanta's Avatar
Setanta Setanta is offline
Send a message via ICQ to Setanta Send a message via AIM to Setanta Send a message via Yahoo to Setanta
Buzzers came as standard in non-US 4th gens so hooking one up might be an answer.
'99 PY DC2R
'85 BBS BMW E30
RIP '90 JDM EF9 Civic SiR
www.performanceforums.com
Old 11-17-2003, 10:08 PM
Killa_CRX's Avatar
Killa_CRX Killa_CRX is offline
When Civics Attack!
You let your girlfriend drive your car??
Honda Enthusiast
Old 11-18-2003, 09:19 AM
Thanks
Thanks for all the help AF people.
Old 11-18-2003, 04:21 PM
Autocratic_1st_Gen's Avatar
Autocratic_1st_Gen Autocratic_1st_Gen is offline
I am thinking of making a relay for mine, I don't like buzzers. Basically it would require the ignition to be on for the headlights to be on....
Ignition goes in to the relay switch terminal, cut the headlight switch wire, one end goes in the switched terminal and the other end connects to the normally off switched ouput. Ground the relay and walla. headlights stay off unless the car is on.
-Dustin
i have a 91 Civic DX with 3x as much money in it as what i paid for it
i wish it was fast
here is my website
http://www.geocities.com/krustindumm/index.htm
Old 11-18-2003, 09:20 PM
balln69 balln69 is offline
Send a message via AIM to balln69
Get a new girlfriend!! One that respects your car
lol jus playin
91 Crx Dx
{[Pensacola]} Crx Representing [{P'Cola}]
({[-Later]})
Drop a Gear
and Dissapear
98 eclipse nonturbo- just turns off. Need help Mighty Pocketz Engine, Transmission and Drivetrain 8 11-03-2010 08:09 PM
brake lights stay on when turn lights on :( help yuraRS Integra 0 03-10-2006 12:48 PM
Turn Lights off jim56 Aurora 7 01-02-2005 04:54 PM
1998 Ranger Turn Signal Problem - Need Help clktenn Ranger | Courier 2 04-28-2004 05:21 AM
1996 Winstar GL - Alarm Went Off - Need Help mdirfan Windstar 0 04-06-2004 05:42 PM
