Old 11-15-2003, 10:05 PM
pflau's Avatar
pflau pflau is offline
Tamiya spray paints are FAKE Lacquer?????
I just tried the tamiya clear spray lacquer TS-13. after it dried I did my usual test and rubbed on some 91% isopropyl alcohol (you can get it from ANY drug store) and the paint came right off
now the only type of paint that can be removed by alcohol is acrylics (thats why you thin acrylic with alcohol).. are tamiya lacquers actually acrylic paints??? if they are then why do they have such a heavy stench???
Old 11-15-2003, 10:14 PM
Kasso's Avatar
Kasso Kasso is offline
Send a message via AIM to Kasso Send a message via MSN to Kasso Send a message via Yahoo to Kasso
Re: Tamiya spray paints are FAKE Lacquer?????
personally i dont like tamiya spray paints. thats y im saving up for an airbrush setup. right now im using testors sray, much much better IMO.
1995 Acura Integra Special Edition (something real special about a 5000 rpm changeover... )
Old 11-15-2003, 10:22 PM
Jay! Jay! is offline
Horizontally Opposed
Tamiya spray paints are synthetic lacquers, so technically, yes, they are fake.
How long did you let them 'dry' before you performed your test?
It has been discussed on this forum and in several articles that they can take up to 4 weeks to fully cure.
Hierarchy of Subaru:
(Click to see mine!)
Old 11-15-2003, 10:57 PM
scaleracecars scaleracecars is offline
What is your point? PPG Lacquer which is what MCW now sells is acrylic lacquer. It also will come off with alcohol. So does ppg clear. You may be even more surprised to know the new Testors line of lacquers are actually base coat/clear coat paints. They will be worthess without a clear coat on the top. Anyway Tamiya paints are the best thing out there. They work better than any other brand of paint we can buy in a can. Do you test all of your paints after they dry this way? If you do then why? Is ther a reason you are worried about alcohol exposure?
Old 11-15-2003, 11:05 PM
CamaroSSBoy346's Avatar
CamaroSSBoy346 CamaroSSBoy346 is offline
Send a message via AIM to CamaroSSBoy346
hm. I wish i knew isopropyl alcohol takes that stuff off. I got a lil over spray on my forumula windshield. I ended up breaking it using mineral spirits trying to rub it off. BTW, Tamiya paint is like testors, it doesnt stick on the corners. I/E where the fender and door meet, the paint doesnt stick until 1mm after the panel line.
2002 F150 SuperCab FX4 6" Fabtech, 3" BL, Detroit locker, Edge tuned, Yukon 4.56s, 37" Nittos, Harley lights, Depo fogs, 8K HIDs, Powerstop brakes
1992 Lincoln Mark VII LSC 302 H.O, A9L ECU swap, 65mm TB, 73mm Granetelli MAF, FRPP 30lb injectors, Walbro 255, MSD ignition, Powerdyne BD11 supercharger, Efans, T-5 swap w/ FRPP flywheel, Ram HDX clutch and adjustable Steeda clutch quadrant, 4.10 gears, Nitto NT555R radials
2000 OBS Tahoe Z71 6k HIDs, 33" Goodyears. 280k mile daily beater
Old 11-15-2003, 11:06 PM
BTW i reccomend Dupli Color over tamiya any day.
Old 11-15-2003, 11:12 PM
pflau's Avatar
I test every new kind of paint I get to see how permanent it is.. Ive found that the more permanent the paint, the more sanding/polishing it can take.. thats why I dont use acrylic on car body because if you sand them they peel.
in my book the three kinds of paint are defined by their effective solvent.
acrylic - alcohol
enamel - paint thinner
lacquer - lacquer thinner
also.. I categorize them by their stench
acrylic - good
enamel - tolerable
lacquer - baaaaad
so the tamiya stuff is as "permanent" as acrylic but smells as bad as lacquer..
and Ive noticed that it shrinks as much as lacquer as it dries from the inside out.. which is different from acrylic and enamel. one thing about lacquer is that it takes a lot of polishing because it doesn't skin over and hide tiny imperfections.
Old 11-15-2003, 11:13 PM
pflau's Avatar
Re: Re: Tamiya spray paints are FAKE Lacquer?????
I think you need to put a few dust coats on first or otherwise the paint will creep away from the edges.
try putting a few dust coats on before heavy coats.
Old 11-16-2003, 02:22 AM
hirofkd's Avatar
hirofkd hirofkd is offline
That's because you try to coat with too thick of a paint at a time, and that's why paint runs away from the ridges. And the body, use primer and spray lightly for the first few coats, and you'll never have the problem with Tamiya, Testor or any brand for that matter.
Hiroaki Fukuda
Old 11-16-2003, 07:23 AM
Zcaithaca's Avatar
Zcaithaca Zcaithaca is offline
fershizzle
Send a message via AIM to Zcaithaca
yea when i use tamiya or testors i put AT LEAST 3 coats on then a top coat.... that should fix tyhe peeling
Zach
Old 11-16-2003, 07:35 AM
Veyron's Avatar
Veyron Veyron is offline
Isopropyl alchohol is used by many of modeler's to strip lacquer paint from their models.
Old 11-16-2003, 08:25 AM
Vric's Avatar
Vric Vric is offline
You better joking right ? Testors Spray is the frist step to scrap a model ! Dont know why, but when I left Testor for Tamiya, all my kit came out with perfect job.. tryed back testor and had problem.. I dont use Testor spray and never will anymore. Stay Away !
I admit Duplicolor paint are good too and less expensive
Old 11-16-2003, 09:42 AM
acrylic - alcohol
acrylic - good
enamel - tolerable
lacquer - baaaaad
You should be able to get a near perfect finish with tamiya paint right out of the can . No polishing required. Also this stuff sticks. Based upon your comments that lacquers don't skin over and hide imperfections I understand a little more about your painting methods. Paint is not designed to fill imerfections. This should be done before and during the primer stages. No wonder you are sanding so much.
Old 11-16-2003, 01:32 PM
Ragnarok043's Avatar
Ragnarok043 Ragnarok043 is offline
Send a message via AIM to Ragnarok043
it doesnt matter that they are synthetic, alcohol can dissolve all types of lacquer. some people even use denatured alcohol to thin their lacquer paints.
Old 11-16-2003, 03:54 PM
Vric's Avatar
Hey Ragnarok043, please down size your signature !! we dont need a wallpaper
tamiya lotus europa special teszion Completed Projects / Gallery 12 02-05-2012 12:41 AM
