Old 11-13-2003, 09:51 PM
jun_crack333 jun_crack333 is offline
Send a message via AIM to jun_crack333
front speakers
my problem is i got a 91 civic 4g4d and the front speakers sound low i could hardly hear them after i put my system on the same thing's happenin' wit' my boys car (same car as mine) wat can we do to make them sound good..
Old 11-14-2003, 12:56 AM
GScivic7's Avatar
GScivic7 GScivic7 is offline
Send a message via AIM to GScivic7 Send a message via MSN to GScivic7
Re: front speakers
what do you mean they sound low??? Like low volume, use some english. If that's the case, buy an amp for them
Empty Pockets Racing Member #1
Old 11-14-2003, 02:53 PM
listen dog
i have an amp but the front speakers are not connected to the amplifier thus they sound very low,now the way they sound is extremely low.they should sound the way it sounded when i did not have a system..... hint.... hint! loud enough (am i speaking english now)
Old 11-14-2003, 04:29 PM
knorwj's Avatar
knorwj knorwj is offline
Send a message via AIM to knorwj
So what is the amp for? subs?, or rear speakers?
good subs with a decent amp will drown out stock speakers especially in a 91 (speakers are old man, the speakers in my teg didn't have any surrounds left when i bought the car!!) and make them sound lower even if they really aren't. of course this can happen with aftermarket speakers as well if they are unamplified. plus some high quality speakers have to be amplified to work properly.
If the amp is for rear speakers then of course the front ones will sound low? they will probably distort sooner then the amplified ones also.
Did you and your "boy" do the installs yourself? if so maybe the amps gains are not adjusted properly, your amp needs to be tuned by someone or you need to tune it after being installed to utilize your specific speakers properly, every speaker need the amp set differently.
Now this is all assuming you meant quieter when you said low?
if you meant they sound as if they are a lower frequency, then maybe the tweeters are screwed up and you are only gettin midranges. i don't really know about that. if they were amplified then there would be a few things that could be wrong but you said that they are unamplifed so then i can really only think of the one thing.
oh yeah by the way... don't get an attitude with people if they are asking you to clarify what you mean in a question. He was only asking you to clarify so he could try and help you , and he didn't have an attitude or anything with you so why pick fight? you'll get more help and gain more respect the more helpful you are.
anyway hope this helps out... if not let us know in a little more detail or maybe clarify on any of the ideas i thought of, so we can try again.
Old:
1993 Acura integra gs-r
New:
1998 chevy BlaZeR2~ AKA "Jeep recovery device"
Newer:
2007 Honda CB900F "919"
Old 11-14-2003, 07:14 PM
GScivic7's Avatar
Re: listen dog
you could also have your highs and treble settings down on your headunit, i would check that too...and I still don't get what you mean by low, like they are putting out low frequencies or low volume?
Old 11-14-2003, 08:05 PM
knorwj's Avatar
Re: Re: listen dog
good point i didn't even think of the EQ on the HU.
I wasn't sure if he meant low volume or low frequency either...
Old:
New:
Newer:
Old 11-16-2003, 04:27 PM
sorry for gettin an attitude but i took it offensive but i think i found a solution ima just connect it to the amp along with the rear speakers
'02 - 6 1/2" Front speakers RMoskowitz Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 5 02-15-2002 09:51 AM
'02 front speaker replacement psykod Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 0 01-26-2002 09:43 PM
'91 G20 Front speakers? Supa_chink Audio/Security 13 01-13-2002 01:42 AM
front speakers dont work! NismoG20 Audio/Security 6 08-06-2001 02:18 PM
front speakers keep cutting out, please help!! GOKOOL Audio/Security 3 06-07-2001 02:42 PM
