Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Audio/Security
Audio/Security car audio, security.
Old 01-08-2002, 08:25 PM
Supa_chink Supa_chink is offline
Send a message via AIM to Supa_chink
Question '91 G20 Front speakers?
I was wondering if anyone knew or has had experience removing door panels off a 1991 G20 (in order to access the front speaker). I have removed all the obvious screws (3 on bottom, one on left side by the catch, and two by the hindge). Is there something else I need to take off or unscrew? The bottom of the panel seems to want to come off, but the top (by the window) seems to be clasped or hooked onto some unseen part. Do you guys have any idea on whats goin on and how to get this damn thing off?
Old 01-08-2002, 10:51 PM
95_G20_P10's Avatar
95_G20_P10 95_G20_P10 is offline
yeah im having the same damn prob with my 95 G i cant get at the fronts
Old 01-09-2002, 02:48 AM
T4 Primera T4 Primera is offline
This is what I did with the Primera but G20 should be the same.
After removing the 6 visible screws as you've stated before, carefully prise out the plastic trim from around the doorlock.
Prise out the electric window switch from the armrest/handle and remove the screw located there.
Release the securing clips around the edges of the panel then slide the panel vertically upwards and it will come off.
Once all the screws are out it is only held on by a central locating pawl (kind of a hook pointing downards). Sliding the panel upwards releases this although you might have to flex it a bit around the doorlock so it clears.
Once it's off just undo the window switch harness if necessary.
"The cause of liberty becomes a mockery if the price to be paid is the
wholesale destruction of those who are to enjoy liberty."
-- Mohandas Karamchand Gandhi
"They that can give up essential liberty to obtain a little temporary safety
deserve neither liberty nor safety."
-- Benjamin Franklin
"The biggest cause of trouble in the world today is that the stupid people are
so sure about things and the intelligent folks are so full of doubts."
-- Bertrand Russell
Old 01-09-2002, 11:48 AM
95_G20_P10's Avatar
ok yeha i wast sure if there was a scre near the armrest. but how do u get at the rear speakers are there screws in the trunk that u have to unscrew cause i think i got all the ones in the car and the back wouldnt lift out??
Old 01-09-2002, 03:59 PM
You need to remove the back seat, then the parcel shelf is just held down with snaps locks front and back (by rear window). Once the shelf is off you can get to the speaker screws.
-- Bertrand Russell
Old 01-09-2002, 04:05 PM
95_G20_P10's Avatar
yeah i cant get out the backs of teh back seat
Old 01-09-2002, 05:18 PM
On my Primera you have to get the seat part out first by pulling the front part upwards. Then you can get at the necessary screws to remove the back of the seat. (On mine, the rear seat is a 60/40 split fold down thing but I still needed to remove the side bolsters to get the parcel shelf off.)
-- Bertrand Russell
Old 01-09-2002, 06:21 PM
Swonder67 Swonder67 is offline
Send a message via AIM to Swonder67
I changed the rear speakers on a p10 without taking out the seats totaly. just fold them down, and take off the clips you can see on the rear deck. there are two hidden ones, they are behind the seat bolsters, justkinda pull them forward and use a flat head screw driver to pop them out. then just lift the deck up and you should have enough room to swap out the speakers.
2003 Nissan Maxima SE Titanium Edition
Cattman Catback Exhaust
35% Platinum tint
Old 01-10-2002, 01:05 AM
95_G20_P10's Avatar
swonder u seem to have all the answers for me ur the one who is alwasy repling to my threads
Old 01-10-2002, 08:57 AM
Whats more funny is, I don't even own a G20. lol
35% Platinum tint
Old 01-10-2002, 10:57 AM
95_G20_P10's Avatar
yeah i know i think u should switch over to the G. i think everyone will agree with me on that
Old 01-10-2002, 08:35 PM
speediva's Avatar
speediva speediva is offline
Send a message via AIM to speediva Send a message via Yahoo to speediva
Okay everyone can bow at my feet...
Read the 10th post here to get answers on removal of front and rear speakers!
I know, I rule! :flash:
Like a boy - but BETTER!
2005 Subaru Forester 2.5X
1997 Honda Civic EX Coupe
Inform yourself:
AF User Guidelines
Old 01-11-2002, 08:19 PM
nis.k.a.'s Avatar
nis.k.a. nis.k.a. is offline
front door: 2 on side 3 on bottom 1 behind window switch 1 behind door handle. unsnap clips around panel. pry under door handle and slide panel up and off. installing is harder because you have to get that central slide clip. MAKE SURE when taking off panel that you don't rip up by the side view mirror this is notorious.
rear SOLID seat: pull up on early P10 or pull tab to release clip and then pull up on 2 tabs (1 on each side, right between your legs if you were to sit down). for solid BACK rest: simply push rest up from bottom to unclip. VOILA
nightmaR3Z
Old 01-13-2002, 01:42 AM
95_G20_P10's Avatar
i insatlled my infinity 4x6's and infinty 6 1/2's with my new audiobhan 4x75 amp. shit be sounding real dope. if ur looking to get a 4 channel amp i recomnd the audiobahns might be expensive but well worth it
