Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 11-13-2003, 08:43 PM
MattyO217 MattyO217 is offline
Fastest 1/4 mi turbo kit?
Was just wondering what your opinions were about what kit would probably give the fastest 1/4 mi times. I have a 1999 Honda Civic Si. I have considered FMAX, REV HARD, GREDDY, DRAG. Assume the internals will be kept stock.
Any other comments on kits for my car are welcome.
Thanks,
M
Old 11-13-2003, 08:49 PM
Dumped91Hatch's Avatar
Dumped91Hatch Dumped91Hatch is offline
Re: Fastest 1/4 mi turbo kit?
Too many factors to decide! I'm prety sure no one will answer this question because there is no definite answer.! Just do alot of research.
Check out my car here My 91 Hatch
Old 11-26-2003, 04:49 PM
jhong1784 jhong1784 is offline
Send a message via AIM to jhong1784
you should check out darg turbo kits
i m a dealer of drag so i can get u one. if u have any questions just hit me up
Old 11-26-2003, 06:25 PM
civicHBsi91's Avatar
civicHBsi91 civicHBsi91 is offline
Send a message via AIM to civicHBsi91
just go all motor! its a b16 its supposed to be all motor
2002 Acura TL Type S
1991 Honda Crx Si
Old 11-26-2003, 06:43 PM
GScivic7's Avatar
GScivic7 GScivic7 is offline
Send a message via AIM to GScivic7 Send a message via MSN to GScivic7
FMAX uses one hell of a wack fuel enrichment system. They require you to use two extra injectors to get the fuel needed. Only heard bad things about the DRAG kit, mismatching turbo sizes and a fucked up fuel enrichment system also. If I were you, I would go with RevHard, ditch all the FMU and delta wastegate and Vortech BOV and go with Hondata, Tial wastegate and a BOV of your choice
Empty Pockets Racing Member #1
Old 11-26-2003, 09:10 PM
civic15.8's Avatar
civic15.8 civic15.8 is offline
rev hard kits dont come with delta wastegates anymore the went to 35mm tial i think if you know anyone that know alot about turbos then ask me to purchase the parts for a custom turbo to fit your goals for the carif not then go with a rev hard stage2 drag and fmax just suck
or if you have the money get a full race but you will have to get a fuel system (i would suggest hondata)
95 integra ls
kyb agx adj shocks
ground control coilovers
I HAVE JUST BEEN TURBOED
future:
str intake manifold
17" rims
apex n1 exhaust
body kit
carbon fiber hood
We need more members: www.hondachat.com
Old 11-26-2003, 09:15 PM
GScivic7's Avatar
Just to be a little more helpful, here's the list I had going for my kit before my car was totaled.
Just ignore the prices and website and all that jazz, just shit I listed so I don't forget where I planned on getting it
Turbo Kit
1. Garrett T3/T04E turbo -- www.hpautoworks.com $550
2. 26.75x6.4x3.5 intercooler -- www.motormatrix.com $275
3. Rev Hard Turbo Manifold -- www.motormatrix.com $449
4. HKS SSQV BOV -- www.hpautoworks.com $190
5. Tial 35m wastegate -- www.hpautoworks.com $225
6. Charge pipes -- Exhaust Specialties in Seattle
7. Downpipe -- Exhaust Specialties
8. Hondata s200 w/Boost -- C-Speed Racing in Bellingham $495
9. Intake & K&N Filter -- Exhaust Specialties & Napa
10. Walbro 255 lph Intank Fuel Pump -- www.importpoweronline.com $105
11. DSM 450cc Injectors -- www.thepartstrader.com
12. CRX resistor box -- www.thepartstrader.com
13. Apex'i N1 Turbo Exhaust & Carsound cat -- www.hpautoworks.com $524
14. Vaccuum lines, clamps & pipe connectors -- Home Depot or Napa
15. Fittings --
16. Oil lines --
17. Autometer gauges and gauge pod --
18. Greddy Profec B Spec-II Boost Controller -- $30
Old 11-26-2003, 09:38 PM
Cool thanks.
What is #12 the resistor box for?
Any thoughts about the Greddy kit?
Old 11-26-2003, 09:49 PM
civic15.8's Avatar
the greddy turbo is just to small for the fastest ¼ mile time plus it is about the same price if not more for the rev hard or drag or fmax
what are your goals do you want to run 14's or do you want to run 13's or 12 or 11
obviously if you keep stock internals you wont run 11's but if you got a nice kit and a good fuel system you probably good run 9 psi on your b16 but if you stay if the fmu that most kits put with their kits then i would say dont go past 7 psi
i meet a guy that went to school with my bother in law and he ran a 13.9 on street tires @9 psi on a stock gsr integra with a custom kit
95 integra ls
kyb agx adj shocks
future:
str intake manifold
17" rims
apex n1 exhaust
body kit
carbon fiber hood
Old 11-27-2003, 12:47 AM
ive seen turbo si's at the track all the time running 14.7 and higher each with diff kits and diff drivers, i just dont see the point in turbo'ing a b16 unless you completely rebuild it, theres a few nice ones putting down great power but the majority ive seen run like ass
1991 Honda Crx Si
Old 11-27-2003, 03:44 AM
have u ever thought of the drag kit for ur car
Old 11-27-2003, 10:21 AM
civic15.8's Avatar
i will never recommend a DRAG kit to someone until they change their stuff. it has a sucky wastegate and smaller turbo and a manifold that wants to crack 9 times out of 10.
the turbo b16 lack torque that is way unless you ebuild it to get some torque it probably wont run as good as the b18's with turbo
if i were you i would go with a rev hard kit it is only 2800 on ebay from one of there dealers (this is where i got mine and they are trust worthy) kit the kit then after a while learn how to drive it then get a new fuel system so you can up the boost a litlle at the most 9 psi cause you still have stock internals and that should get you into mid to high 13's
95 integra ls
kyb agx adj shocks
future:
str intake manifold
17" rims
apex n1 exhaust
body kit
carbon fiber hood
Old 11-27-2003, 07:03 PM
boostinintegra boostinintegra is offline
My 00 integra ls ran 14 flats at like 80+ mph with only a drag turbo kit...running the set 5psi...after that larger injectors, fuel pump, apexi afc good good tuning and a boost controller can give you a low to mid 13 sec car easy...all on stock internals...rememebr tuneing tuneing tuneing
Stage 4 turbo kit Dr.Mambo666 Performance 26 12-23-2006 01:24 PM
2.4 turbo kit for sale MTB. Cavalier 1 12-29-2005 06:48 PM
3.4 Turbo kits berzerker Camaro Discussions 6 07-16-2005 11:08 AM
3.4 Turbo kits berzerker Camaro Discussions 1 07-15-2005 11:00 PM
4 turbo kits available johnnyBgood Eclipse 2000+ 141 03-01-2005 06:34 AM
