Old 11-13-2003, 08:28 PM
projectsilvia97's Avatar
projectsilvia97 projectsilvia97 is offline
Send a message via AIM to projectsilvia97
ls/vtec swap
hey guys. i was looking at importbuilder.com. i took a look at their b18b block package. http://www.importbuilders.com/block.html it's part number 0021, package number 6. it looks pretty good to me, since i was goin turbo. i was mainly looking at the ls engine, just cuz of it's build and tranny. could somebody please tell me the difference between the IB Spec Wiseco Pistons, JE pistons, or Arias Pistons? you can choose between these sets, and i don't know much about piston brands and such. also, what does balancing and polishing the crank do? what is the difference between the b18a and b18b? i was thinking of turboing this setup with a t3/t4 hybrid custom setup, or maybe even a t4. sorta thinking that the t4 is too big. tell me what you guys think.
thanks
Old 11-13-2003, 11:11 PM
eckoman_pdx's Avatar
eckoman_pdx eckoman_pdx is offline
Honda God
Send a message via AIM to eckoman_pdx Send a message via Yahoo to eckoman_pdx
Re: ls/vtec swap
thanks
Well, I'll answer the question about the difference between the B18A1 and B18B1.
The B18A1 is from 90-93 Integra's that were not a GSR model.
The 90-91 B18A1 had 130hp@6000 rpm and 121 ft/lbs of torque at 5000rpm.
The 92-93 B18A1 had 140HP@6300 rpm and 126 ft/lbs of torque@5200 rpm.
The B18B1 is from 94+ Integra's that were not a GSR or Type-R model.
The 94+ B18B1 142 HP @ 6300rpm and 127 ft/lbs of torque @5200rpm
I hope this helped a bit.
Also, the 90-93 B18A1 had a cable tranny and a mechanical speedo.
92+ civics and 94+ Integra's used a hydro tranny and a electronic speedo. That being said, the B18B1 has a hydro tranny and an electronic speedo.
Also, the B18A1 came non-obd in 90-91 I believe and OBD1 in 92-93. The B18B1 was OBD-I in 94-96 I think, and OBD-II 97+.
Old 11-14-2003, 04:32 PM
Jeff C's Avatar
Jeff C Jeff C is offline
Re: ls/vtec swap
As far as I am concerned, its 6 one way and half a dozen the other. I am using and know of several that are using JE's. I know of several using Wiseco, and I know of a 900+hp Supra using Arias. I dont know of the actual differences though.
-1989 Honda CRX Si, B18A Pic FOR SALE
-1998 Honda Accord EX Sedan 5spd
-1981 Chevrolet Silverado, shaved and bagged Pic
Old 11-14-2003, 05:00 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
I have heard more good things about the JE's than any others for turbo, but don't have any personal experience with them and boost. Also try a T3/T4 hybrid turbo that will be a good choice for your application.
Old 11-14-2003, 06:17 PM
Could you guys tell me what balancing and polishing the crank does?
Old 11-14-2003, 06:26 PM
Jeff C's Avatar
Well, when they balance the crank, they actually balance the whole rotating assembly, crank, rods and pistons. They are looking for any slight wobble that might might occur. They will grind off, I am talking very very little, the parts that are creating the wobble. When they polish the crank journals, they are essentially smoothing out the contact surface, therefore reducing friction.
IMHO, I would not worry about either of these too much unless you are real serious about modding/racing.
Old 11-15-2003, 10:09 AM
i was just asking because it comes with the whole deal, and i didn't know what it did. how much boost do you think i would be able to run with this setup? i says that it can handle 35+ lbs. of boost. is this true?
Old 11-15-2003, 06:18 PM
Jeff C's Avatar
Re: ls/vtec swap
IB knows what they are talking. I cant tell you myself though.
Looking for info on a LS/VTEC swap Hatchin '88 - '91 Civic | CRX | Wagon | Shuttlee 3 10-06-2003 11:52 AM
LS/VTEC Swap Article Kaiser Integra 0 06-25-2003 09:24 AM
About the Ls/Vtec swap PhatAck813 Integra 1 07-16-2002 11:56 PM
LS VTEC SWAP Help!!!!!! 98 CivicEX Ls/Vtec '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 0 07-16-2002 06:59 AM
LS/VTEC swap question skippy19 Integra 8 01-30-2002 02:32 PM
