Go Back   Automotive Forums Car Chat > Classic Cars
Classic Cars Do you just love the classics?
Old 11-13-2003, 03:36 PM
akumabito akumabito is offline
Engine swap on Mustang
I'm looking for info on the possibilities of an engine swap on a Mustang. I want to replace the 5.0 engine with a 429CUI engine from a '68-'73 Thunderbird. Is it possible? Has it been done before? (Pretty sure it has..) Any major problems? What gearbox to use, Mustang's or Thunderbird's? Any sites about this subject?
Thanks a bunch peeps!
Old 05-26-2004, 10:01 AM
n2racing n2racing is offline
Re: Engine swap on Mustang
You can find the mounts, oil pan, headers at Summit or Jegs. www.superford.org may help. There are some discussion forums you can use.
Old 05-26-2004, 10:38 PM
Layla's Keeper's Avatar
Layla's Keeper Layla's Keeper is offline
Supermodified
What year Mustang is it you want to perform the swap on? Judging by the mention of the 5.0, it's a Fox Body, right?
If this is the case, then a 429 swap is not a particularly good idea. At least not the T-Bird 429 (a relative of the 390, if I recall the engine right) which is NOT even close to the infamous semi-hemi Boss 429.
Either way, you're looking at relocating the steering box, fabricating mounts, custom headers, custom adaptor plate for the transmission, probably an engine flexplate, and a whole lot of headache.
A much easier swap is to find the Ford/Lincoln 460ci V8 which is available as a crate engine and thanks to many kits is practically a plug and play unit. Though, I will say this, be prepared to drop any road racing pretensions. That 460 is a heavy as hell beast, but are you going to argue with an easy 500+ lb ft of torque?
Proud Owner/Operator of Haven Raceway and Hobby!
dakota engine swap jpuckett13 Dakota 0 08-23-2010 07:21 PM
engine swap Cadillakin'98 S-10 1 10-22-2009 09:33 AM
engine swapping E. Frank Performance 6 08-07-2009 06:37 PM
1998 Mustang V6 engine knocks and runs rough birdstash Mustang Problem Diagnosis 2 06-04-2009 09:59 PM
97 Jimmy engine swap gsnats Problem Diagnosis 5 03-06-2009 09:40 PM
