Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora
Old 11-13-2003, 03:09 PM
csprings csprings is offline
Question Issues installing Remote Start
I have a new Jetta 1.8T and wanted to instakk a remote starter. Any issues people are aware of interms of interfering with security system or others aspects.
Looking for something to self install, any recommedned models? Don't need keyless entry on most of the ones I've seen so far.
Thanks
Old 11-13-2003, 09:57 PM
bigblackone bigblackone is offline
you will need to use one of your keys (valet probably) and get it taped onto the steering wheel or in dash somewhere that the car can read the chip in it, otherwise it will not start.
Anyone have any other ideas?
Old 11-13-2003, 11:00 PM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
Re: Issues installing Remote Start
Thanks
It's a pretty easy car to do an install in. I did a few including my '01 Jetta GLS. The only thing is that the car itself is terrible and if you have ANY problems, the dealer will try to deny any warranty work because of the remote starter, stereo, or air freshener.
If you plan to do this, I would really find a good shop to have it installed. If you never have done one, it's kinda hard. I would suggest finding a DEI dealer. They are the best out there. If longest range, warranty, and ease of use are important to you, goto DEI. www.directed.com
Also, get a 555u interface for the factory security system. If you just stick an extra key up near the ignition cyl., it can cause the BCM to lock you out. This can happen even when you try to start it with the key. It "sees" 2 correct codes and messes things up. Sticking a key up there is the old way of doing things and was never really recomended.
Old 11-13-2003, 11:09 PM
Cool - I knew someone out there would have a better idea ... also cs ... you didn't mention if this was a auto or manual tranny ...
trick for the VW dealer is to find one that is good to you
Old 11-15-2003, 08:30 PM
sergent sergent is offline
Send a message via ICQ to sergent Send a message via AIM to sergent Send a message via Yahoo to sergent
Re: Re: Issues installing Remote Start
easy on a gaz,,but not easy on diesel.. nobody can help me ,, I am looking for the right wire,, need a tach on my jetta diesel.. and cannot find it in my dash,,
Old 11-15-2003, 09:05 PM
Re: Re: Re: Issues installing Remote Start
ooh try tdiclub.com ... they have a wealth of knowledge there ... let me know if they can help ...
Old 11-15-2003, 10:15 PM
Email me with the EXACT make model and year of VW you have along with what kind of remote start you have and I can get what you need.--Steve [email protected]
Old 11-17-2003, 06:10 PM
Re: Re: Re: Re: Issues installing Remote Start
Here, just do this. Just go to an ignition coil or fuel injector and use one of the uncommon wires. What I mean is on the injectors and ignition coils there will always be a wire that is the same color on ALL of the injectors or coils. So, use the other wire.
Help with remote starter / alarm installation WMX267 Explorer | Explorer Sport Trac 6 11-10-2009 09:36 AM
Dealer Installed Remote Start 2004 LS lincoln04 LS | MKZ 3 07-25-2005 10:51 AM
Need help to install remote start on Accord 91 Sccord 91 Accord/TSX/Accord Hybrid 2 02-28-2005 02:28 AM
Installing Remote Start MGK MKL TrailBlazer | Trailblazer EXT 2 06-26-2004 08:11 PM
possible to install remote start on a standard? slammed89civic '88 - '91 Civic | CRX | Wagon | Shuttlee 9 12-05-2002 01:36 AM
