Old 11-13-2003, 03:06 PM
goodles goodles is offline
tranny problems
I have a 96 excort with the 4 cyl 1.9
ON cold starts i will start driving, but the first time that I slow to a stop, at a stop sign or light, The tranny drops into neutral and will not go into gear. I have to rev the engine up until it pops into gear. It is a good tranny, the entire car only has 40, 000 miles on it and it is completely cherry, and since a new tranny is $2300 , i need help. Has anyone else had this problem with that tranny ( for the 1.9 liter engine, automatic tranny, fllor shhift). If you have had that problem, what did you do to fix it. any help will be great.
Old 11-18-2003, 01:32 PM
Steindawg94 Steindawg94 is offline
Re: tranny problems
95 escort with similar problem, had to have tranny rebuilt, cost less than replacing it. Ask around.
Old 03-17-2004, 07:28 AM
MechWarrior MechWarrior is offline
tranny problems
Just read you post today. I suggest you check the brake fluid since the transmission runs off of a hydrolic clutch system. The brake fluid reservoir also feeds the slave cylinder that controls the clutch when you step on the pedal. If the fluid is low it may not be getting enough pressure to fully disengage the clutch.
99 Pontiac Montana Tranny problems? wilson8260 Montana/Montana SV6 9 12-22-2009 09:16 PM
96 sc tranny problems please help phantom309 SC/SL/SW 6 04-28-2009 02:27 PM
92' S-10 Tranny problem AK47 SRH420 Interior | Exterior | Appearance 3 02-20-2009 03:41 PM
tranny problem or engine/tranny mount? jbjslambert LeSabre 4 12-13-2008 11:03 AM
Tranny problems and maybe other problems. P0700, P0740, P1776 SupraSeth94 Caravan | Voyager 15 06-14-2007 06:24 PM
