Old 11-13-2003, 12:41 PM
oKIR oKIR is offline
Question Difference between B16A1 and B16A2
I just want to know what the difference is between the b16a 1 and 2 !! And if they will fit tha same mount in the car... (Speaking theoretically)
Old 11-14-2003, 04:58 PM
Hybrid1990crx's Avatar
Well the b16a2 as about 10 or so more horse power, not really sure why. Head flows better? I have no idea, but would like to know if someone can answer that.
And the b16a1 has a cable tranny, while the b16a2 has a hydro tranny. if you have a fourth gen, which I guess you do, the b16a1 will go in easier, since fourth gens also have cable trannys. 92 and up have hydro trannys.
Old 11-15-2003, 09:06 AM
maxspeedhonda's Avatar
maxspeedhonda maxspeedhonda is offline
Send a message via AIM to maxspeedhonda Send a message via Yahoo to maxspeedhonda
The 10 or so extra horsepower come from the slightly higher compression ratio.
Old 11-16-2003, 12:25 AM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
Re: Difference between B16A1 and B16A2
heres some b16 info for you.
http://tech.hybridgarage.com/tech/b16/index.html
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 11-16-2003, 02:59 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
the b16a2 runs OBDII while the b16a runs OBD0.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 11-17-2003, 04:46 AM
eckoman_pdx's Avatar
eckoman_pdx eckoman_pdx is offline
Honda God
Send a message via AIM to eckoman_pdx Send a message via Yahoo to eckoman_pdx
well, techincally the b16A1 came from the civic 1.6/VTi in europe. But is has the same power rating as the JDM first gen B16A. (In japan, there was never a B16A1, B16A2, etc rating, just B16A). The B16A2 is USDM from the Del Sol Vtec. The B16A3 is USDM Si. Both are rated at 160hp. The B16A3 is ODBII, the B16A2 is ODBI (unless there was a 97 Del SOl Vtec, that B16A2 would be OBDII if they made one). The first gen JDM B16A was rated at 158hp and was non-ODB, the second gen JDM B16A was rated at 168hp, and was ODB-I. The JDM 3rd gen B16A was ODB-II, same hp as 2nd gen. The reason for the power bump of 10hp in the 2nd and 3rd gen JDM B16A vs the JDM 1st gen B16A (and the USDM B16A2 & A3, the european B16A1) is that it has a 10.4:1 cr vs the 1st gen's 10.2:1. Also, the 1st gen JDM and the european B16A1 had a cable tranny. All others had a hydro tranny.
Old 11-17-2003, 05:08 AM
dejoux's Avatar
dejoux dejoux is offline
Send a message via ICQ to dejoux
B16A's in Japan were never officially called B16A1 and B16A2 but they still get called it. (not just in US but in JDM countries like Japan and NZ)
B16A1 - 160hp. Cable tranny. Came in EF9 Civic SiR, EF8 CRX SiR and DA6 and DA8 Teg XSi
B16A2 - 170hp. Hydro tranny. EG6 and EG9 Civic SiR, EG2 Del Sol SiR, DA6and DA8 Integra XSi facelift plus EK SiR
The differences are B16A2 has OBD1 instead of OBD0 wiring, different rocker cover, higher compression, different cams.
HTH
AF's resident BMC expert
One by one the penguins steal my sanity
Old 11-17-2003, 08:45 AM
imprtsyco imprtsyco is offline
Send a message via AIM to imprtsyco
so if i was doing ls/vtec i would want the b16 head right, opposed to the b18,s?
Old 11-17-2003, 08:34 PM
Honda God
You can use a GSR or B16A head for an LS/Vtec. However, the B16A head flows better by 5.25% and also has silighty more displacement than the GSR head, 42.7 to 41.6 (the LS head is 45cc). An LS/Vtec with a B16A head would be 1832.17cc. A LS/Vtec with a GSR would be 1831.07cc. A regular LS is 1834.47cc.
Old 11-17-2003, 11:58 PM
integra818's Avatar
integra818 integra818 is offline
Send a message via AIM to integra818 Send a message via Yahoo to integra818
[quote=eckoman_pdx]The B16A2 is USDM from the Del Sol Vtec. QUOTE]
Dude, we never got a Del Sol in America with a B16, you're probably thinkign of the 98+ Civic Si.
Old 11-18-2003, 02:55 PM
SteveDX89's Avatar
SteveDX89 SteveDX89 is offline
Send a message via AIM to SteveDX89
Re: Re: Difference between B16A1 and B16A2
Wow, this is something I'd never expect from someone with over 2000 posts.
Steve
89 Accord DX Coupe
Old 11-18-2003, 03:51 PM
integra818's Avatar
I'm not a postwhore, if that's what you're tryin to say. The guy said Del Sols in in AMerica came with B16s...then siome kid thnks del sols have B16s for a while, which is wrong info.
Old 11-18-2003, 04:39 PM
crxlvr's Avatar
actually integra the 94-95 Del Sol came with an option for the B16a3 motor. there were the base del sol, the s model and the del sol vtec which had the b16.
however eckoman, the b16a2 is from the USDM 99-00 Si's and the b16a3 was the USDM 94-95 Del Sol Vtec.
1991 Honda CRX
2003 Honda Accord
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 11-19-2003, 05:05 AM
Honda God
Dude, the Del Sol DID COME WITH AN OPTION FOR A B16A FOR A FEW YEARS. IT WAS CALLED THE DEL SOL VTEC, MANY YOU'VE HEARD OF IT. This is not wrong info, but fact. Ask Honda, go find a Del Sol Vtec and pop the hood. Regular trim Del Sol's had a D16Z6, not B16A, but the Del Sol Vtec trim (made in 96-97) had a B16A under the hood from the factory. It was not a mass produced car, but it was produced. Del Sol's in the us did come with a B16A....not all del sol's, but some, the Del Sol Vtecs. (I beleive the 96-97 Del Sol's came with the option for the B16A powered Del Sol Vtec)...I get so sick of people coming in here and saying things like this without properly looking up the info. There were 2 cars in the US released with a B16A...the Del Sol Vtec (B16A) and the 99-00 Si (B16A). Neither were a mass produced Honda, per say, like the EX, etc civics were. But they were released. Look up the codes, all the engine books, etc, all list the Del Sol Vtec as having a B16A as well as the Si. I can't believe someone actually came in here and told us "you're wrong, the del sol never came with a B16A, must have been thinking of the 98+ Si." Ok, besided that being wrong (The Del Sol Vtec had a B16A), the Si was not 98+, it was 99-00. Get the facts straight before you say them.
To crxlvr, you may be right about the exact codes, though I swear I remember it the other way around. I'll check out the codes when I get home tonight to see which one had the B16A2 and which had the B16A3. I'll post it tomarrow. I have multiple sources I can cross-reference there, so I'll check and post it tomarrow afternoon.
Old 11-19-2003, 01:19 PM
integra818's Avatar
Aright, aright, relax man, a small slip-up and you go ballistic on me, chill out. The fact that I've NEVER seen a Del Sol with a stock B16 has led me to believe that they never came with that engine, even tough they do. MY mistake, you don't have have to burst into flames and shit like that.
Differences between '05 and '06 1.6 Engines? edr_bug Aveo 0 08-06-2009 11:51 PM
Physical difference between GSR and Type R motor (B18c1 and B18c5) bd307 Engineering/ Technical 15 09-24-2005 10:37 PM
difference between b16a1 & b16a2 jlshondacrx90 '88 - '91 Civic | CRX | Wagon | Shuttlee 16 07-10-2005 10:01 PM
Difference between 99 and 00 and 01 engines Hunterw450 Cherokee 1 02-21-2005 12:26 AM
engine differences between 89 and 92 and up gen2tegls 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 1 04-10-2004 07:57 AM
