Old 11-12-2003, 10:21 PM
dontbhatin dontbhatin is offline
changing non turbo to a turbo help
I have a 91 eagle talon 2.0 non turbo ,and a 91 mitsubishi eclips 2.0 turbo that has a bad tranny and head gasket. I want to take the turbo and put it in the talon. Can I do this with out to many problems. Here is a list of what I think I need to take, if anything else please tell me. 1 turbo, 2 manifold, 3 front exhaust pipe, 4 intercooler+piping, 5 fule pump,6 fule injecters, 7 spark knock sensor, 8 mass air sensor, 9 engine wiring harness, 10 ecu.
Old 11-14-2003, 03:09 AM
boots03 boots03 is offline
Send a message via AIM to boots03 Send a message via Yahoo to boots03
you will also need to have an oil pan,stronger c/v shafts, oil lines, and i belive a bigger exoust, i am thinking about doing the same thing to my 92 talon, and i belive this is all that you forgot. ohh ya, and u will also need i belive a differnt cat.
Old 11-14-2003, 03:23 AM
Re: changing non turbo to a turbo help
hell i forgot a really important one, you will also need camshsafts too, the lobs are differnt
Old 11-14-2003, 01:30 PM
Thanks for your help. can I use the cams from the mitsu?
Old 11-14-2003, 05:16 PM
I belive the cams on the talon/laser/eclipse all have the same turbo cams.
Old 11-14-2003, 09:41 PM
thanks I think I'll try it . I'll fallow up when i'm done
Old 11-15-2003, 11:04 AM
ninety-five-awd ninety-five-awd is offline
the easiest way to do this?
don't do it. way to much trouble. you might as well just move the whole motor from the mitsubishi into your talon. you have a good tranny in the talon right? so just do an engien swap. when your done get a new head gasket and your in business. no extreme fabrication really necessary.
Old 11-15-2003, 04:47 PM
the mitsu is an automatic, dont they have a diffrent crank
Old 11-17-2003, 01:04 AM
no, its the same crank, but your car does have the 4G63 in it i belive, so if ya want, just say the hell with it, and replace the head on the engine in the car you want to turbo, just transfer it all over as one unit, thats what one of my buddies did, then he put all the turbo/manifold/piping on last, in my mind, that would be the easiest thing to do
Old 11-17-2003, 12:39 PM
I was thinking the same thing it would be pretty easy that way.
Want to turbo a 96 Eclipse 2.0 non turbo donidavis Engine, Transmission and Drivetrain 7 12-02-2010 08:23 AM
89 probe gt turbo TURBO LEAKAGE sweetbiker Probe 0 03-08-2009 04:25 PM
Non-turbo turboed track time nates6969 Engine, Transmission and Drivetrain 33 11-01-2006 06:38 PM
mod to make non-turbo turbo? blake240 Off-Topic 5 03-19-2004 11:55 PM
how about a non vtec turbo b20? edman24 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 2 03-15-2003 04:17 PM
